Installation Problems, "could not write the receipt"
Hi there
First of all: Sorry for my english, it's not the best one... Some days ago, i bought a Mbox Micro, and there was still PT LE 7.4.2 included. I installed it (Mac OS X 10.5.6, MBP Alu), and the installer told me several times "Installation failed, could not write the receipt for ... Plugins". I tried to install all the components separately, and that worked. Today i registered my purchase and could download Version 8 for free, so i did that. Now, when I'm trying to install it, the installer tells me again, that a failure occured (could not write the receipt for Plug-In Updates). But now, this happens also when I install only the Application files. Does somebody know a solution for this problem? Thanks and best regards from Switzerland Jonas Last edited by thegordian; 02-18-2009 at 07:11 AM. Reason: my english.. :) |
Re: Installation Problems, "could not write the receipt"
nobody?
Are you installing from an Admin account? If not, that could be the problem.
You might also check the permissions on your Receipts folder located at MacHD>Library>Receipts - it should have Read & Write access for System and Admin and Read Only status for 'everyone'. |
Hi
I just tried again, and it worked... Strange! Is it possible that there are problems if the installer file is still in the "Downloads" Folder? I copied on my desktop before. Thanks anyway for your answer Cheers Jonas |
2 Problems after Upgrade PT9 to PT10: "Controller-Personality MBox3" and "MP3.dll" | Eviltubbie | Windows | 5 | 07-03-2012 10:39 AM |
"Unable to write receipt for plug in updates" | Freddyroc747 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-29-2012 06:20 PM |
The installer could not write the receipt for "plug-in updates" | Dedelman2005 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-22-2009 08:53 AM |
help!? "the installer could not write the receipt for "plug-in updates"?? | onosai | Pro Tools TDM Systems (Mac) | 2 | 10-15-2009 08:32 PM |
Installer can't "write the receipt"???? | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-26-2008 10:39 AM |
