Old 10-06-2010, 04:41 PM
stanonbass stanonbass is offline
Default HD Native question
Can you use older hd interfaces with the new HD Native? Persay a 192 io or 96 io?
Old 10-06-2010, 04:42 PM
mattrixx mattrixx is offline
Default Re: HD Native question
Apparently you can!
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
Old 10-06-2010, 05:17 PM
DigiTechSupt's Avatar
Yes, you can - any of the 'older' HD interfaces (192, 96, 96i, etc) will work with the Native card.
Avid Audio Tech Support
Support FAQ
Old 10-06-2010, 05:48 PM
ProTooler ProTooler is offline
Does the legacy port work for my 888/24's?
Have a great day.....
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Mojave with 64 GB RAM
PT Ultimate (2019.10)
Motu 16a
C/24 Control Surface
Old 10-06-2010, 05:58 PM
WildHoney WildHoney is offline
ummm, who's Persay?
Old 10-06-2010, 06:32 PM
ejsongs ejsongs is offline
what about input/recording latency? is it the same has a tdm rig
what about the mixer...it is a 32bit/64 bit mixer vs 48 bit fixed....doe it sound the same?
ej
Old 10-06-2010, 09:14 PM
friedsalami friedsalami is offline
Will HD Native work with Apogee AD/DC such as the Rosetta series?
Old 10-06-2010, 09:50 PM
Nice!!
Im building a second studio and this cut my cost way down.
I will use native for tracking and hd3 for mixing. Nice my current interfaces will work!! Bonus!
Old 10-06-2010, 10:37 PM
Firechild Firechild is offline
Nice!!
I recommend the other way around. PT Native is more Post than tracking due to it´s pretty basic low latency monitor protocol.Unless you are monitoring through an external mixer, then it make sense.
HD3 PCIe, HD I/O , HD10.3.10, Mac Pro 6 core , 24 GB RAM , GTX285 , 10.8.5 , UAD-2 Quad Satellite , ATC SCM25A Pro with ADAM Sub 12.
Old 10-07-2010, 06:45 AM
Tony Cariddi's Avatar
Tony Cariddi Tony Cariddi is offline
Hello ProTooler. Unfortunately the legacy ports are not supported when using legacy HD interfaces with HD Native.
The throughput latency of HD Native, when using an HD Series interface, running your session at a 64 sample buffer and 96k sample rate, is 1.6 ms. By comparison, Pro Tools|HD delivers a throughput latency of only .44 ms at the same sample rate.
HD Native uses a 64 bit floating point mixer with 32 bit floating point processing. Whether this sounds better than 48 bit fixed is a subject of debate as doing math in fixed v. floating has pros and cons on both sides.
Avid does not test 3rd party interfaces, however interfaces that work with Pro Tools|HD will likely work with HD Native.
Tony Cariddi
Marketing Director
Question for those that have used HDX and HD/Native albee1952 Pro Tools HDX & HD Native Systems (Win) 13 09-05-2013 07:05 PM
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
HD Native Question ronstephens macOS 12 08-12-2011 04:37 PM
Question about HD Native Psychonaut4 Pro Tools HDX & HD Native Systems (Win) 8 04-01-2011 12:48 AM
SSL4000 native/ Renmaxx native/ DUY everpack native!!! cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2007 07:58 AM
