Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 03-30-2011, 02:30 PM
Psychonaut4 Psychonaut4 is offline
Default Question about HD Native
I'm thinking about taking The HD Native plunge and was wondering if HD Native includes ADC. ADC as in HD ADC or is it the same as PT9? Thanks.
"Well bartender it's a pain to see. I'm the bad mother [bleep][bleep][bleep][bleep]er called Stagger Lee"
Old 03-30-2011, 02:36 PM
CME CME is offline
Default
What is the difference? In theory native adc should be practically unlimited. It's HD that limits adc to 4096 samples.
Unless you mean the lower latency TDM provides. And that is HD/TDM exclusive.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 03-30-2011, 06:12 PM
Default Re: Question about HD Native
HD Native offers Hardware I/O Compensation like TDM only.
Aaron Mulqueen - 001 HD Native
Old 03-30-2011, 06:59 PM
Thats great. I use A lot of analog gear and that's a big selling point with me.
Old 03-30-2011, 10:27 PM
Shan's Avatar
Shan Shan is offline
Just to add some additional info, the round trip hardware latency value has to be calculated and entered manually in the I/O Setup under H/W Insert Delay. This value can only be entered in msecs at this point. From there, that value will be included and calculated in the ADC engine automatically.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 03-31-2011, 04:50 AM
CME CME is offline
Default
Shane
And I believe this is available in all versions of pt9. I just don't use any outboard gear to set this up.
Old 03-31-2011, 04:43 PM
"Originally Posted by Shan
Just to add some additional info, the round trip hardware latency value has to be calculated and entered manually in the I/O Setup under H/W Insert Delay. This value can only be entered in msecs at this point. From there, that value will be included and calculated in the ADC engine automatically."
I understand this. I am asking if it is the same with HD Native.
Old 03-31-2011, 05:52 PM
Yes, the H/W Insert Compensation is the same but the H/W I/O Compensation is Pro Tools HD Only.
Old 04-01-2011, 12:48 AM
Shan's Avatar
Correct. In HD and HD Native we can bypass the H/W I/O Compensation if needed. In PT 9 and the old LE/Mpowered line, it's always on. Just to clarify, in PT 9 and the old LE/Mpowered line, HW I/O compensation does exist, it's just always on. In HD, we have a preference to bypass both input and output delays separately if needed.
Shane
Question for those that have used HDX and HD/Native albee1952 Pro Tools HDX & HD Native Systems (Win) 13 09-05-2013 07:05 PM
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
HD Native Question ronstephens macOS 12 08-12-2011 04:37 PM
HD Native question stanonbass Pro Tools HDX & HD Native Systems (Mac) 13 10-07-2010 12:14 PM
SSL4000 native/ Renmaxx native/ DUY everpack native!!! cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2007 07:58 AM
