Problem with fwx card.
I buy fwx card with my venue dshow console.
My problem is that when launch protools and record or playback the protools stop and said that i have a problem with audio buffers, i have the audio buffers to 2048 but the protools stop anyway. I launch nuendo and select the digidesign asio driver with 1024 buffers but the audio playback with many clicks. How can i solve this? |
Re: Problem with fwx card.
Sounds like a pro tools issue,
Are all other programs turned off? Is your computer fast enough to run pro tools properly? |
I had a similar problem when recording it would stop after 20 minutes or so. After increasing the buffer size it went away. Make sure that it is recording to the firewire drive. Also are you using a hard drive with the approved firewire chipset?
The pc is a core 2 duo 2GHZ with 4gb ram. The procesor is lower 10% usage and the hard disk lower 15 %.
However if i use nuendo with a m-audio soundcard i can record and playback ten track ok, but with the dshow fwx the sound crash. With protools m-poweres all ok, my problem is with the dshow console. |
Music business is serious business. |
I am using a serial ata 2 hdd but if only record four track the sound fails, the hdd transfer is at 6 %.
Need opinions: Do I have Core card problem or computer problem? | johnnyv | Pro Tools TDM Systems (Mac) | 2 | 08-11-2010 06:36 PM |
HD Card boot up problem | decibelboy | Pro Tools TDM Systems (Mac) | 3 | 05-22-2009 09:04 AM |
001 card problem | m001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-13-2003 10:21 AM |
Problem with my PCI card?? | Mr T | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-06-2001 11:31 AM |
dsp card problem | paul dean | Digidesign Hardware & Software | 4 | 02-09-2000 03:48 AM |
