just bought a new external reverb unit, need help
Hello. I am really new to the whole computer based audio game, so please please help out as much as you can. I hope i don't sound to lame here.
Ok, I have a 002R, and just bought a TC electronics M300. It has the S/PDIF connecters on the back, so i thought i would use those. How do i use them? How can i make the M300 an insert in the track, like the other plug-ins. Basically how can i set it up, using S/PDIF, to make the effects actually come through. Please, if you have the time, give me easy to follow instructions. -michael- |
Re: just bought a new external reverb unit, need h
you connect the spidfs respectively with 002r digital out to M300 digital in
and vice versa then in hardware setup uncheck spidf mirroring then to send to it in the bus section send to spidf out and on an AUX track set input to spidf in |
i cannot find anywhere in my hardware setup anything that says "uncheck s/pdif mirroring."
That option doesn't exist with the 002R, don't worry about it. Just set it up like mersisblue suggested and skip that part
ooops sorry didnt know 002 / 002r dont have that
I still couldn't get any sound, none of the LED's are lighting up on the M300 either. Can you explain the process in more detail?
-michael- |
just make sure you have the cables put in right way: 002R:s output into M300:s input and the other way, and then make sure you have the M300 set to use the digital connection.
in protools, you select insert just the same way as any plugin, but instead of selecting plugin from the plugin list you select spdif i/o from the i/o list. it's that simple.
You also need ot ast the i/o on the TC to digital.
I highly suggest you download the free, extensive PDF manual from the support section of this website as well. |
Please Suggest external reverb unit with 002r | tpthai2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 12-17-2007 02:45 PM |
Best way to route in an external reverb unit | rtm | Pro Tools TDM Systems (Win) | 1 | 11-11-2007 11:28 PM |
how do i use an external reverb unit with 002r? | maskedman72 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 33 | 06-17-2005 06:27 PM |
External Reverb Unit in PT LE6.4 | rcourell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-18-2005 08:52 PM |
Will this work? 001 used as External Reverb unit.. | Matt Whritenour | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-07-2004 10:28 AM |
