Old 11-13-2018, 05:36 AM
headlap headlap is offline
Default Xpand directory for PT First
What directories should I put the files from setting g up xpand!2? I can't seem to find xpand!2 when I'm in Protools First thing
Old 11-13-2018, 07:05 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Xpand directory for PT First
The installer should take care of putting all the files where they are supposed to be in order to make Pro Tools First work properly.
What platform are you on and did you run the installer for PTF?
Will
System Details
Old 11-13-2018, 08:44 AM
PC, Windows 10
Did not put on the xpand files. Should I reinstall?
Old 11-13-2018, 10:40 AM
junkgear's Avatar
Yes, reinstall and let the installer put the files where they need to be.
Will
System Details
Old 11-14-2018, 05:24 AM
I reinstalled and when I go to the xpand plug in, there is only an organ there. There is supposed to be a ton of instruments? Where the heck are they? I used protools express before this and never had issues with plugins.
Old 11-14-2018, 06:09 AM
Southsidemusic's Avatar
If you do a search on the drive you use as main C:/ you should look for a .BIG package and that is where you need to point Xpand2! to so it k ows where to look. I think it is called .big but maybe someone can chime in if you can't find it. On top of the Xpand plugin you have a few dropdowns and there you find the option to point to the .big file for sounds for Xpand2!
Let us know how you get on.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
PT Installation Directory Longcut Pro Tools 12 9 04-10-2018 12:15 AM
Kontakt 2 directory stevegalante Virtual Instruments 1 09-16-2006 07:52 AM
OSX Open Directory SteveH44 Post - Surround - Video 7 07-27-2006 07:16 AM
Template Directory Issues BenTerry Pro Tools TDM Systems (Mac) 2 04-07-2004 05:10 PM
5.1 directory issues lupe Pro Tools TDM Systems (Mac) 0 04-15-2001 10:37 AM
