Protools with Creative Asio ZxR SoundCard
Hello! I'm using ProTools 10 with the Creative ZxR sound card.
When I run protools. I get the following error. And protools closes. "Pro Tools hardware is not installed or in use by another program" The protools it´s original. I run it in windows 8.1 pro 64bits. All my drivers are updated. What could be happening? |
Re: Protools with Creative Asio ZxR SoundCard
I would guess your soundcard is also your default audio device for your computer. The OS may not be releasing the driver so PT can use it, so change your OS settings so it is not the default device, then try starting PT.
You can also try holding down the 'N' key while PT starts. This will reset the audio system and prompt you to choose a playback engine. |
Creative ASIO and PT10 | rtman26 | Pro Tools 10 | 3 | 06-11-2013 04:34 PM |
Creative ASIO Help no sound | Zece | Windows | 0 | 02-06-2013 01:49 AM |
Creative ASIO has taken over | sabayachi | Windows | 3 | 07-10-2012 11:08 AM |
Mbox Orig as ASIO soundcard? | buckaroo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-17-2006 01:16 AM |
5.1 ASIO soundcard & drivers | SimpleNatureSpirit | Post - Surround - Video | 4 | 08-21-2004 12:32 PM |
