Old 10-11-2007, 03:46 AM
mirok mirok is offline
Default standalone driver problem with digi 002 rack
Hi there, I'm using digi 002 with mac book core 2 duo 2.0 with 2gb ram. I installed standalone driver version 7.3 and is not working properly. In core audio manager I see digi working properly, when I open logic pro 7.2 digi normally starts, but I couldn't hear any sound from it. Also in mac and logic preferences I only see built-in audio card. Do I have to turn built-in card of? I'm using digi 002 for quite some time now, but with G5 (one before intel series) and it works fine (also just standalone driver). I'm abroad right now and have only mac book with me, so I need to work with this setup. Thanks for help.
regards, mirok
Old 10-11-2007, 04:07 AM
Default Re: standalone driver problem with digi 002 rack
I have mac osx 10.4.10
Old 10-11-2007, 04:49 AM
Hi Digidesign, I've just realised that my version of mac osx seems to be the problem, but since 10.4.10. is out from June 20th, you should provide update for us! I need to work with my hardware synths and I can't because of malfunctioning hardware.
regards, mirok
Old 10-11-2007, 11:35 AM
DigiTechSupt's Avatar
The 7.3 Core Audio driver should work fine with 10.4.10.
It's not clear from your post what, exactly, is happening. You say you can launch the Core Audio Manager and it shows connected, yes? Are you keeping it launched, then launching Logic?
Avid Audio Tech Support
Support FAQ
Old 10-12-2007, 05:30 AM
hi there, thanks for your reply...when I launch logic, everything seems to be fine, but I can't see digi in logic preferences nor in mac preferences although midi works fine and if I route built in card output with digi alt input I also can hear a sound, so the card works fine, just drivers don't. When I launch core audio manager (it doesn't show manager in dock when logic is launched) it shows card is connected, but when I press disconnect the card and launch manager again, the card is still connected. What seems to be the problem?
Kind regards, Mirok
Old 10-12-2007, 09:55 AM
Please start with the steps in the OS X Setup and General Troubleshooting sticky at the top of this forum, specifically those areas on trashing preferences, including the file 'com.digidesign.coreaudiomanager.plist'.
Also, can you tell me the version of the Core Audio driver you have installed? Go to MacHD>Library>Audio>Plug-Ins>HAL and Get Info on the Digidesign Core Audio driver to see the version number.
Do you also have Pro Tools installed and, if so, which version?
Support FAQ
Old 10-13-2007, 02:53 AM
Hi, I tried everything and still the same, I don't have PT installed and driver version is 7.3
regards, Mirok
Old 10-15-2007, 09:18 AM
do you have any idea what to do?
regards, mirok
Old 10-15-2007, 10:20 AM
Please create a new administrator account and test it from there - let us know if anything changes.
Support FAQ
Old 10-15-2007, 01:28 PM
savage1 savage1 is offline
I have had a similar problem with the 7.3 CoreAudio driver.
I was attempting to use the 002 with DP on 10.4.9 and
the Digidesign Hardware option does not appear in the Audio Set up
prefernce pane OR the MOTU hardware config. MOTU says it should work.
Standalone Audio Driver for Windows 7 for Digi 003 [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-06-2013 05:20 PM
Standalone Driver for 002 Rack and OS X Lion pianoguy88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-16-2012 05:45 PM
Eleven Rack Standalone driver, and editor. Blurgh Eleven Rack 22 01-09-2012 09:16 AM
Standalone Audio Driver for Windows 7 for Digi 003 [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-16-2010 09:44 AM
Propellerheads Reason & digi driver standalone istvankantor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-25-2005 12:58 AM
