ProControl in Surround Mode -outputs confusion
Hi there
I did the setup for a mix in 5.1 and I encountered a problem. I connected the outputs as specified in the manual and all the monitoring sources work: Stereo Mix= Left-Right; SRC1= Ls-Rs; SRC2= C+Sub The problem is that the signal from Center & Sub (Aux 5-6) bleeds to the Ls & Rs. If I pan to the left surround, I get the center signal too, and if I pan to the right surround, it will go to the subwoofer as well. Does anybody know what the problem might be? (I'm using ProTools 6.9) |
Re: ProControl in Surround Mode -outputs confusion
Double check your cabling. I remember there being two different versions of pin outs on the DB25 connector. One prior to a certain serial number and one after.
That's all I can think of. Jim |
Confusion about Bounce To Disk in Low Latency Mode | Jperkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-13-2009 03:15 PM |
SPL Surround Monitor & Film/ProControl Format | One Track Music | Post - Surround - Video | 4 | 08-23-2007 07:13 AM |
Automation flip mode on procontrol | webstereo | Pro Tools TDM Systems (Mac) | 1 | 10-01-2005 12:23 AM |
ProControl&Surround | 071 | ProControl, Control|24, Command|8 | 1 | 02-23-2001 08:18 AM |
grid mode & my confusion | thenegativedivine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-21-2000 10:49 PM |
