#621
Re: Best Core 2 Series Desktops-Results and Specs
Nick, the 1440 X 900 setting was available and that turned the rectangles back into squares. Thanks.
Sunburst, my firewire is the ASUS VT6306 VIA. So maybe I don't have the problematic version? That would be nice. The good life is mine!
Pro Tools 12.4 HDN, PCIe, Omni & Digi 192 ASUS Sabertooth, Intel i7 3820 3.6Ghz 32 GB 1600Mhz Corsair RAM SSD 500GB Samsung WIN 10 64bit |
#622
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#624
Re: Update on My Quad Build
the G0 stepping runs cooler than the B3 stepping and with NEWEGG you DO NOT know which stepping they will ship you. CLUBIT tells you which one. so on my build i got everything from NEWEGG except the Q6600 cpu. there are builds on the DUC that have used the B3 stepping (because of release timing and availability) but i think at this point most would want the G0 stepping because of the better core temps. and tho i was not familiar with CLUBIT before my search i was definitely pleased with their service!!
#625
Thank You mykhal. I will check them out.
Support Independent Artists!! You can start by visiting www.myspace.com/2gonline |
#626
Pro Tools LE
Just wanted to let you know for about 12 bucks more you can pick up the Antec P182 case, which make routing cables much easier. Check out this review.
FatBelly Slim Oh no, not the sprinklers again. |
#627
Thanks Fat Belly. I think I will go that route. Well What about this case? Antec P182SE Antec P182SE Silver Mirror-finished stainless steel ATX Mid Tower Computer Case - Retail
Also will Win XP Home be fine instead of Win XP Pro?
#628
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#629
Nah not that I know of. I might gone ahead and jump and get Win XP Pro.
#630
Finally did my testing, it's been running great. Very quiet and my dverb 2 test scored 289 without any overclocking or much tweaking Only thing that was weird is that after installing all of my plugins, my dverb count went down to 256 ? I thought that was strange, is that normal?
i7 Builds - Specs and Results | mykhal c | Windows | 7144 | 04-15-2024 12:10 PM |
Intel Quad Core vs. i-series | solidwalnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-23-2010 05:16 AM |
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-12-2009 02:24 AM |
are these specs ok? (low budget 2 core) | korkman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-22-2008 02:44 AM |
8 Core Mac Pro, Leopard and Windows results | pasanta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-13-2008 06:51 PM |
