Shortkey command for mix/edit window switch
Im sorry, i was unable to search the forums for this, for some reason i could not come up with keywords to search for that would give any search results...
so anyways, whats the deal with Ctrl+= command, it doesnt work.. i dont think any "=" commands work im on win vista and pt8 btw |
Re: Shortkey command for mix/edit window switch
This shortkey works ... I use it continuously because i have just one monitor to work !
It works fine on my systems as well.
On my German keyboard, I have to use "Ctrl" and "+" for the switching... Maybe you can try this one.
I just tested again to verify mine is working fine(I have dual screens so I don't use this shortcut). Could you have a bad key or maybe your keyboard is set to some language other than English which might change that key? Does keyboard focus need to be on?(make sure it is on and try again).
Is there a key command to zoom in vertically on the channels is the edit window? | BillytheB | Pro Tools 11 | 6 | 03-17-2014 03:22 AM |
Key Command Edit Window Change Track Height All Selected? | DFT | Pro Tools 10 | 3 | 03-08-2013 02:20 AM |
How to: Switch between sub-windows: Midi editor inside of edit window | bashville | macOS | 3 | 10-20-2012 07:59 PM |
PT LE 8 BUG: Shortkey doesn't work when a plugin window is open | ugosound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-24-2009 11:09 AM |
Leopard Command M Minimizes Edit Window !!! | TommyT | Pro Tools TDM Systems (Mac) | 4 | 08-14-2008 06:15 PM |
