Mac Pro/G5 Rack Alternatives/Options
id like to have 2 mac pros racked (sideways) along with a 192.
besides sawing off the handles... (to fit a 19 inch rack)_ what is there? |
Re: Mac Pro/G5 Rack Alternatives/Options
Didn't a company called Marathon make a rack for this.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Unfortunately, Marathon went out of business years ago. The two current rack solutions I'm aware of are from Redco & Cadlock.
http://www.redco.com/shopexd.asp?id=876 http://activatethespace.com/cadlock.html Warmest Regards, Brian |
Unfortunately, if you want it horizontal, you must cut off the handles or find a new case to place the MacPro's innards into as a standard rack is 19"... I chose the first option.
It was very easy, just remove the RAM and HD's and then tape off the machine's holes and grills with blue painters tape. This tape comes right off,and leaves no sticky stuff, but stays in place well while doing the cutting. Then get a fine hack saw blade in your jig saw and cut straight across the handles. The hard part was making the custom brackets used to mount the MacPro into the standard rack. I wound up using the old Marathon G4 rack mounting hardware. I found the spots where I could use bolts and nuts on the inside of the MacPro without disturbing anything and then drilled the holes. It looks great and is really sturdy. I'm glad I did it. I actually did this to a G5 first and then sold it for way more (2x) than what unmodified G5's were selling for at the time when I upgraded to PCIe. -gH |
I'd go even 1 farther.... if you have 2 sliding rack rails like the Marathon rails, you could conceivalbly mount the rails into the top & Bottom handles just before they curve horizontal that way you have the mac attached at the top & bottom vertically & still be able to slide it out & open it... even the right side mac that would have it's access hatch located on the rail side .. the rails should be above & below the hatch so that mac's interior would be accessible as well,..
Just my 2 cents.. Cheers , Tom. |
Any chance of seeing pics of this mod? I still have my old G4 Marathon rack mount pieces, and have no aversion to whacking the handles off a Mac Pro
just be careful investigate thoroughly before cutting some macs aren't meant to fun horizontally....especially the water cooled ones like mine... i loved my marathon G4 great for on location recording when i did a church gig on sunday's i gave it to a young kid i thought had promise
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
I remember some models of the liquid cooled G5 didn't like going horizontal. My understanding is that the Mac Pro's should be fine with it. I have seen the Redco vertical mount kit, and although I could fit two of the 192's and the Sync I/O next to the Mac Pro, I would still be giving up valuable space in my remote rig. Besides, there's something about taking a hacksaw to a gorgeous Mac Pro that might be cathartic on some level....
Just ran across this: http://cgi.ebay.com/ws/eBayISAPI.dll...=263602_263622 A wee bit pricey, I must say. Last edited by Michaels; 06-12-2010 at 03:05 PM. Reason: Added link |
Pro Tools HDX 2021.6.0 Lynx Aurora 16 Ross Martin PCM4222 Ross Martin Super Beast Apple Mac Pro 8 Core 2.66Ghz 16GB RAM OSX 10.14.6 http://www.keith-moore.org |
that eBay thing-a-ma-jig is only for a G5 and only one model of g5
no 2 models of the G5 or Macpro had the same internal mountings and hardware, so unless you modify a case of your own computer you could very well be wasting a bunch of time and money cutting the handles off is really easy if your able to use tools correctly I've done this 12 times at least, once the handles are cut the computer will fit on a 4 space shelf and if you mount anything above the computer it gets locked in really tight... no need to drill and attach rack ears at all If you chosse I can do it for bit cheaper than the dumb eBay thing also if the internal rack dimensions are 20" across replacing the rack rails with ones 6u shorter or cutting the rails, the computer will fit sideways without cutting anything I have drawings available
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
002 Rack w/LE 8.. upgrade options? | darkgoob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-16-2013 03:59 PM |
SC 48 output options without a mix rack | amerikiwi | VENUE Live Sound Systems | 4 | 02-14-2013 05:27 PM |
VI Rack options? | nikki-k | Pro Tools 9 | 2 | 11-12-2010 06:26 AM |
FOH Rack Options | james tebb | VENUE Live Sound Systems | 2 | 02-28-2010 01:56 PM |
Monitoring Options With 003 Rack | Blank Frank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-11-2008 08:23 PM |
