Old 06-14-2010, 12:57 PM
Jeff ONeil Jeff ONeil is offline
Default Help-delay when starting record
Right off the bat...I'm NOT a PT power user. I'm a voice talent,
I've made a PT system change that results in a 4 second delay after hitting begin start when recording.
The track is armed, preroll is off. I usually just hit 3 on the keypad and the recording begins on the track.
I've scoured the PT resources manual but cannot find what I have changed.
Any help is greatly appreciated.
Jeff
Old 06-14-2010, 01:17 PM
Runnytofu Runnytofu is offline
Default Re: Help-delay when starting record
Sounds like you've turned on the count off feature.. open your transport window (Apple-1), and make sure the midi section is showing on it (View/Transport/Midi Controls).. there should be a little box in the midi section that says "Count off".. if it's lit up, that's your problem right there. Just click on it to turn it off.. or just hit 8 on your numeric keypad to toggle the status.
Hope that helps.
Old 06-14-2010, 01:24 PM
Hope that helps.
Runny...you are a genius! That was the problem. It became a global problem which was driving me a little batty!
Thanks so much for your help!
Jeff
Metronome starting with delay goga macOS 2 05-01-2011 01:32 PM
Delay between PT starting and BFD starting Baritonealone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-01-2008 03:58 PM
What's a good starting value for H/W insert delay andre tchmil Pro Tools TDM Systems (Mac) 3 11-20-2004 02:58 AM
delay starting recording on Pt HD3 pepasmax Storage Subsystems 1 07-28-2002 10:05 PM
big delay when starting recording on PT HD3 pepasmax Pro Tools TDM Systems (Mac) 6 05-13-2002 04:13 PM
