Old 04-02-2020, 09:03 AM
DaveGross DaveGross is offline
Default 2020.3 Quicktime 32 bit error???
Hmm..Catalina on a 2017 iMac 4.2. All the latest updates.. Why this message when importing a ProRes 422 video with audio? Video works great, but I'd kinda like my Audio sync reference....
"Cannot import Quicktime Audio because this version ProTools relies on 32-bit QuickTimeComponents that are not available with this OS. Please see Avid.com for the latest compatibility information"
dg
Old 04-02-2020, 09:30 AM
Default Re: 2020.3 Quicktime 32 bit error???
Not all video formats are supported on Catalina
Old 04-02-2020, 09:35 AM
Yup! That's why I waited until ProRes 422 was blessed.. What's weird is that the video works totally fine, but it won't import the embedded audio from it.. that seems really odd to me as ProRes 422 is a main standard video format.
dg
Old 04-02-2020, 09:37 AM
It was in the release notes, video support only for some codecs
Old 04-02-2020, 09:52 AM
yup! So.this is what's confusing me, based on the release notes at this link and under the Catalina heading... I'm reading this as the h.264 is the one where 'picture will import, but audio will not". If the case is that Audio will not import from ANY of these codecs under Catalina, it should say that. SOOO.. what's a workaround for getting that audio off the Prores, etc Master? I do have my AAF or OMF from my editors, but I sure do like a reference :)
http://avid.force.com/pkb/articles/e...-11&popup=true
Supported Codecs
macOS Catalina (2020.3 and above)
QuickTime (MOV/MP4/M4V Import/Playback)
DNxHR
DNxHD
Apple ProRes 422 (including HQ, LT, Proxy)
H.264 (c,e) (CFR only)
Note: Picture will import, but audio will not.
dg
Old 04-02-2020, 11:22 AM
Shutter Encoder will do it easily, and for free.
http://www.shutterencoder.com/en/
Drop your movie into it, select WAV under Choose Function, choose 16 or 24 bit, press Start Function. NOTE: it seems like Mix Audio Tracks is the correct setting if the audio on the movie is already stereo.
Scott Gatteño
Old 04-02-2020, 12:08 PM
Thanks Scott!!! That's perfect. Donation made as well!
dg
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
Quicktime wrapper error when importing Quicktime file QuacksMeUp Post - Surround - Video 6 11-04-2015 05:07 PM
Pro Tools Quicktime Error... LiricoMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2011 01:59 PM
Bounce To QuickTime error in PT8 daisytone Pro Tools TDM Systems (Mac) 3 07-14-2009 11:57 AM
bounce to quicktime error kalashnikovjohn Pro Tools M-Powered (Mac) 0 09-07-2006 05:00 AM
