Re: PT Crashes every time I reduce playback buffer
This crash happens even with an empty project, and no audio, no tracks?
Then look at your audio interface. Maybe you can take it out of follow DAW buffer size and set it to the lowest amount? Then try again in PT and see if you can change the PT buffer size down to the audio interface lowest amount. I'm on a Mac with PT HDX 2019.10, so I can only offer troubleshooting suggestions. Otherwise, a support call to Avid?
PT 2024.3 Ultimate HDX, Dual Slate Raven MTi2, HD IO 16x16, Mac Studio M2 Max on Sonoma, 64GB RAM, 4 TB & 8 TB external SSD NVMe drives, Neve 1073OPX(2), Slate VSX, Focal Solo Be6, Roland V-Drums, DW drums, too many VI’s and plug ins to mention. |
PT crashes after launch when playback buffer is changed | banjo71 | Pro Tools 12 | 0 | 01-25-2019 06:55 PM |
Opening MIDI plugin during playback CRASHES PT every time. | gsguitarest | macOS | 1 | 12-06-2012 01:18 AM |
H/W buffer size cannot reduce any further | Mike1360 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-17-2012 11:40 AM |
H/W Buffer Size - reduce - increase?? cant win | bigstribs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-20-2010 04:50 AM |
CPU Conflict Reduce H/W Buffer... | Jonathanginese | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-26-2009 10:08 AM |
