Expansion Chassis Advice on 4 or 6 Slot
I am considering my upgrade options right now, going from PPC G5 to an Intel Mac Pro. I've read in threads that the PE6R4 chassis does not introduce any latency, does anyone here own/use/have experience with the PCI4DRQ 4 slot chassis?
For the extra money I don't need the 6 slot, I have 3 cards now and would consider bumping up to 4 which would be more than enough. I just want to make sure I don't make a bad purchase decision and get something that will introduce incompatibility issues/problems (more so than a chassis already can/will). I also realize the 4 slot isn't officially qualified by Avid. Any wisdom would be most appreciated! Ron
ron [k] Musician/Programmer/Engineer/Remixer System: PT HD v8.0.1cs2/PT 9 HD3 Accel, 96 I/O, 96i I/O, Control |24, Midi I/O, Sync I/O ___________________________ http://myspace.com/ronk http://ron-k.net/studio.html http://facebook.com/ron.k.music |
Re: Expansion Chassis Advice on 4 or 6 Slot
I'm in the same boat and am considering the same thing. Anyone try this?
Martin Trum |
Can't say if the PCI4DQ will or won't fulfill your needs but the specs for the 4 slot are quite a bit less than the PE6R4 Magma PE6R4... PCIe host interface card (x4) • Six PCI-X slots (64-bit/66 MHz) PCI4DRQ.. SUBPEHIFX1: x1 PCI Express® host card option 4 PCI slots (32-bit/33MHz) Chris
hey
i ended up getting that chassis and i'm having an amazing amount of problems... but not sure it's the chassis all works fine in native anybody having DAE errors with this chassis?? thanks j |
I don't know if this helps, but I'm using the Magma ExpressBox 4 which is a 4-slot PCIe-to-PCIe chassis and having no problems. I also have a UAD2-Solo and UAD2-Duo inside the computer (MacPro 8-core, 2.GHz.). Everything seems to get along.
Jeff
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24; PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R |
SBS 7 slot bit 3 PCI expansion chassis. | Seeee | Pro Tools TDM Systems (Mac) | 1 | 08-28-2004 08:25 PM |
SBS 7-Slot Expansion 32-bit Chassis & PT 6/ G5 | Mt.Everest | Pro Tools TDM Systems (Mac) | 3 | 03-11-2004 01:21 PM |
DIGI 7 SLOT EXPANSION CHASSIS/PT-HD | acesfull | Pro Tools TDM Systems (Mac) | 7 | 01-25-2002 07:56 PM |
Slot Order for AVOption/5-Slot Mac & Expansion Chassis | Samhein | Pro Tools TDM Systems (Mac) | 0 | 05-01-2001 09:40 AM |
SBS 13-Slot Expansion Chassis | Dirk Buro | General Discussion | 4 | 08-30-2000 08:57 AM |
