Old 08-13-2000, 08:07 AM
tld tld is offline
Default Strange problem in Hardware Setup dialog
I have a Mix+ (PT 5.0) with one Apogee AD8000 interface. When I go into the Hardware Setup dialog the 'Interface' section does not appear at all as it used to below the 'Interface Port' section. I know it was there before, and I had 888/24 IO selected. It still has the other fields for sample rate, sync etc. The interface and PT is working. I tried trashing the DigiSetup but no change. What's this all about????? TIA.
Tom
http://www.digitalaudiorock.com
The Protools Plugin Preset Co-op
Hardware Setup Window Dialog Missing QuickPuppy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-01-2013 07:55 AM
What??? MBox3, 8.05 No Hardware Setup Dialog Box!! Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-01-2011 01:30 AM
Can't access Hardware Setup Dialog??? Jepse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-18-2005 09:54 AM
Hardware setup dialog labels disappeared (6.1.1) apetrocelli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-24-2003 06:08 AM
DIGI 001, no Ch 1-2 input in Hardware Setup dialog!? jcoker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-31-2003 04:53 PM
