DADmom question
I have PT Ultimate Native with a MTRX + DADmom. Recently a problem cropped up with my monitoring using the DADmom.
In the DADmom setup I have ProTools Main Out mapped to Source A, and Mac Audio Out via Dante Virtual Soundcard mapped to Source B. I usually set this setup to SUM rather than SWITCH so I can listen to Pro Tools and Mac audio at the same time (e.g., listening to QT mov files while auditioning audio via PT). A new issue has appeared however. If I have both Source A and Source B buttons lit to hear both SUM sources, and listening to Apple Music on the Mac, if I deselect PT Source A, the volume drops by about 6 db on Apple Music. Same as if I'm listening to Pro Tools Source A and deselect Mac Audio Source B, the Pro Tools level drops by about 6 db. This only happens about 50% of the time, and in fact while writing this the problem has temporarily disappeared. I'd like to solve this because it affects my meter levels in Pro Tools. For that reason I set the DADmom to SWITCH as often as I can, but I'd prefer to leave it in SUM. Pic of my DADmom setup attached. Any advice appreciated...thanks.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
Re: DADmom question
Greetings,
Are you engaging any fold downs ever? Are you driving DADman from just the software or also EUCON with or without MOM? The monitor section of MTRX / DADman should have absolutely no bearing on the metering in Pro Tools. Pro Tools is simply a source input via DigiLink into the summing of additional sources contained within your primary Monitor in the DADman monitor profile. Are you then using a meter output perhaps to send -> back into Pro Tools with an AAX metering plug-in? Let us know a few versions if you don't mind: DADman MTRX Firmware mainboard cpufw DVS & Dante Controller macOS Version Any other relevant details. Thanks! Jeff |
Re: DADmom question
Thanks Jeff-
I'm not using EUCON; just a DADmom configured through its software. I see there is a newer version of the DADman software and MTRX firmware. Here is the version I'm currently on: MTRX. cpufw: 2.3.1.3, matrix 1.1.23.2, recovery 1.2.1.1 DADman ver. 5.4.2.1 (5.4.2 build 1) Dante Controller ver. 4.2.3 (4.2.3.1) Mac OS Catalina 10.15.7 I have a single FOLD DOWN to Mono. I am not using a meter output back into Pro Tools with an AAX metering plug-in. I may be describing the signal flow incorrectly, but I do hear these volume drops when 2 Sources are engaged on the DADmom. Looks like I should update everything first to see if the problem goes away... Thanks--
Re: DADmom question
Good plan. It is also recommended to click "Remove Unused Groups" from the Monitor Profile window - if you've never done this in the process of building or revising your primary monitor profile.
Jeff |
Re: DADmom question
I see the DAD site has version 5.4.5 while Avid's version is 5.4.4.
Is it advisable to go with Avid's older version, or okay to use DAD's?
Re: DADmom question
Thanks--
MTRX Mono SUM function for DADmom question | SomeOtherGuy | Pro Tools | MTRX & MTRX Studio | 8 | 03-02-2020 01:19 PM |
fruity loops in pro tools question...not regular rewire question | nutrinoland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-23-2010 12:39 PM |
quick question - Mbox Mini question - i forget | JRup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-18-2009 02:55 PM |
General Venue Automation Question - (Maybe dumb question) | TwoPort | VENUE Live Sound Systems | 5 | 12-21-2007 02:41 PM |
Chipset Question/Hard Drive Question | andrewkstone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-26-2006 08:15 AM |
