#21
Re: Avid Control Frequently Disconnecting with Silicon Macs
When its in this state can you please collect the logs and post a link to them in a PM
#22
Thanks so much. Is that with "collect support files" from the Eucontrol menu bar?
#23
Yes
#24
I too have had what seems to be exactly the same issue. I have 4 x S1s and 1 x Dock that are all working flawlessly, but the Avid Control app drops out every 10-15 mins or so. The interface seems to 'freeze' and nothing is updated (ie, timecode display doesn't change when Pro Tools is playing), and controls are unresponsive. If I restart the app, the connection is restored, but it drops out again after the same amount of time. If I do not restart the app, eventually the app crashes and I'm returned to the iPad home screen - at this point I loose the currently recalled layout on the S1s.
I have tried 3 different iPads, and 2 different Lightning-USB-Ethernet adapters - all exhibit the same behavior. All Eucon devices are running on an independent subnet, and are connected to an unmanaged switch (the unmanaged switch connects to the managed switch via 1 cable, so that the subnet is properly defined and managed) - there is no other traffic on the subnet. I have also tried connecting the iPad directly to the managed switch (to see if the unmanaged switch was the cause of the problem) and the results are the same. It's worth noting that the dropouts only seem to occur when working in a Pro Tools session - the iPad Avid Control app remains responsive all day if the DADMan is the focused app. Likewise, if Pro Tools is open, but no session is loaded the app remains responsive. It does not seem to matter the complexity of the PT session that's running - a simple session with 40 tracks or a complex mix with 400 tracks - the behavior is the same I never noticed this behavior on an Intel Mac, although I haven't used an Intel Mac with the exact setup that we're currently running. Currently running: MacOS 12.5.1 - Mac Studio 2022 M1 Ultra w 128GB RAM PT 2022.12.0 Eucon 2022.12.0.81 iPad Pro ML0F2X/A iOS 16.2 Avid Control App Version 2022.12.0.140 Ubiquiti UDM Special Edition Router Ubiquiti USW-Enterprise-24-PoE Managed Switch Netgear GS116Ev2 Unmanaged Switch |
#25
I've been having similar issues with the Control app, previously 2022.9 now 2022.12, on 3 x Fire 10 HDs (S1s), and 1 iPad (Dock). But our wifi is pretty mediocre at the moment, so I was just chalking it up to that.
Scott Gatteño |
#26
#27
#28
I tried running all Eucon devices directly into the unmanaged switch (without connecting the unmanaged switch to the router). Surprisingly the Avid Control App stays online for longer (hours, not minutes), however it ultimately still disconnects - this has been repeated over several days of usage
#29
I've been getting this since going Apple Silicon, too. In my case, unmanaged switch directly in to Mac via Belkin adaptor. 4x Artist Mix's and an Artist Control + Avid Control app.
Exactly the same setup I've been running for many years without issue on an Intel machine. I've also tried running Control on Wi-Fi, but behaviour is the same. This has been a problem for the past 3 EuCon versions and past 6 PT versions. A workaround I've found (and also one that demonstrates this is not a network issue) is to run EuCon and MC_Client in Rosetta mode. No crashes/freezes. When it's running natively in Apple Silicon mode, it crashes/becomes unresponsive all the time which causes me to lose my layout as I'm working. It's done this in both Pro Tools and Logic. Pretty much unusable at the moment running natively. Workaround is fine, but inefficient/unsustainable long-term. Monterey 12.6.1, PT 2022.12/2022.10/2022.9/2022.7/2022.5/2022.4, EuCon 2022.12/2022.9/2022.4 MacBook M1 16" 2021 |
#30
Just wanted to follow back up on this thread since the problem has been fixed for me thanks to some help from EddieJones. I am now running the eucontrol app in Rosetta mode on my Mac, and the issues have completely went away.
Find eucontrol in your Applications folder, right click, and hit "get info". Click on the option to "Open in Rosetta". Then restart eucontrol . From what I can tell, there's no difference in my system's performance from running this in Rosetta. Just a massive improvement in stability. |
Control surface options with the upcoming Apple Silicon version? | Phil O'Keefe | Pro Tools | 9 | 01-11-2023 06:32 PM |
Most Waves plugins cannot be set properly from Avid control surfaces / Avid Control? | XJENSEN | Avid S1, S3, Dock and Control App | 3 | 08-11-2022 06:59 AM |
Spectrasonics 2.7 – adds VST3 and native support for Apple Silicon M1 Macs | unkJE | Virtual Instruments | 0 | 06-17-2021 09:49 PM |
Any way to temporarily bypass the Avid Fast Track Duo without disconnecting the USB? | S.Clements | FireWire & USB Audio Interfaces (Mac) | 0 | 06-04-2014 10:19 AM |
MC Control always disconnecting, no sync, offline | RaToX | Artist Series | 0 | 03-24-2011 08:53 AM |
