Old 09-30-2021, 04:10 PM
SoundEng1 SoundEng1 is offline
Default UA's New Console Tracking Mode (CTM)
Protools Needs this badly!!! would love to see this type of feature inplemented.
Old 09-30-2021, 05:27 PM
LDS LDS is offline
Default Re: UA's New Console Tracking Mode (CTM)
Sure, lets get Avid to build a whole new separate 'console' application so that it can be like Luna, which is trying to be like Pro Tools.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 09-30-2021, 06:46 PM
noah330 noah330 is offline
I agree. Do not want.
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
Old 10-01-2021, 07:24 AM
nstu nstu is offline
A BIG Yes for „CTM On“ option when working with carbon - and for sure when you are use a external hardware console.
Input persist at any time - even in playback/pre&post roll together with the playback track.
Listen back with an artist together and hear what the artist is saying to a recorded part.
The UA Basics video shows how great this Option is (https://m.youtube.com/watch?v=WdlzkSqs2ds)
And if someone don‘t want/need that - let that option off. Very simple for all.
Gesendet von iPhone mit Tapatalk
Old 10-02-2021, 12:03 PM
Exactly! Thank you!
Old 10-02-2021, 12:06 PM
Never said build a whole console so it could be like Console/Luna, I said it would be great to have this type of feature implemented.
Old 10-03-2021, 01:21 AM
Originally Posted by Robruce View Post
Yup. Coming from an analog (board) background it is a giant PITA to not have this option. It would vastly improve the punch-in experience in particular.
However, it'll likely never happen for PT with non-Avid hardware.
But in PT with non-avid hardware you can turn off auto-input so that you only listen from the external analog console. This is not possible with carbon (yes I know, this is not the dsp concept behind carbon, but this option or a other workaround would be nice like a „ctm mode“.
The fast and easy solution would be to have a option to turn off „monitoring a recording track while recording“. Than you could use an aux track as an input, monitoring (engineer + artist independent) from this aux track while recording and feed the recording audio channel from that monitoring aux track if you want to track with plugins enabled or set the recording track to the same input if you don‘t want the plugin sound recorded. And we don‘t need another console software.
All users are happy (dsp tracking, „ctm mode“, analog console)
And this option already exists in pro tools version but not for carbon users. Would be very simple to engage in PT 2021.10 or 11 - Avid are you following this?
Old 10-03-2021, 03:43 PM
Eric Lambert's Avatar
I don't get that impression at all. Luna emulates a console in ways PT also does, so they unavoidably share certain qualities, as every DAW does. Luna feels quite different to me.
Old 10-03-2021, 07:50 PM
RobertDorn RobertDorn is offline
HEAR HEAR. I’m very close to pulling the trigger for an HDX system , but I’m so attached to this workflow with an ‘always live’ input while tracking vocalists, that it feels like a step back when this is not possible with HDX, while this is possible in the Native environment in low latency input monitoring on.
Also, smart thinking, if such an option would be there it solves it all, make a track preset for the live vocal input aux with an Aax DSP compressor on it and a reverb send, and you can punch in on any vocal track in the session.
Also think about situations where you want to punch in on vocal tracks with heavy fx / filters etc on it: it’s no fun to disable those inserts first before you’re ready to track , and recording on a separate vocal track and then dragging each take to the destination track is also a really time consuming workflow killer.
Would be awesome if it could be implemented!
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3
Old 10-05-2021, 03:32 PM
UniversalAudio's Avatar
UniversalAudio UniversalAudio is offline
Universal Audio
Thanks for the interest in LUNA.
Just an FYI, this feature as been in LUNA since v1.0. Only the vid is new.
Can the 002 console onboard built in compressor be used in tracking trauha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-21-2015 07:28 PM
Autotune 5 not tracking pitch in graph mode ritaM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-03-2007 07:02 PM
TRACKING w/ REVERB PLUGIN in LOW LATENCY MODE? minor2nd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-10-2005 01:27 PM
tracking ITB then mixing on a console. Seeee Pro Tools TDM Systems (Mac) 5 01-22-2005 11:39 AM
live console for tracking jkung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-17-2003 12:11 PM
