Old 12-30-2014, 08:09 PM
Torchlight Torchlight is offline
Default PT 11.3 is a nightmare!!
I just upgraded from 11.2.1 to 11.3. For starters, the Bounce to Disc function is still NOT working and Avid claims that it's been fixed. And to make matters worse, now I cannot get the system to even record!! Imagine that, a DAW that will not record. So, since there is no way to do an uninstall easily with PT 11 (no uninstaller) I went to the Sweetwater website for advise (it came up first in the google search if I recall). They had a very specific set of instructions on how to uninstall PT 11 and I followed them. I then went back to PT 11.2.1 and when I opened a session I noticed that all my 3rd party plugins are GONE!! I do see the Waves V9 plugins in the Apps folder but PT 11 doesn't see them. Needless to say this has been one heck of an evening. Any suggestions on how I can get PT 11 to once again recognize all of my Waves V9 plugins and the other 3rd party plugins I have (Lexicon LXP Native). I am very disgusted right now with what 11.3 has caused. 11.2.1 worked fine except for the Bounce to Disc function. Thanks.
Old 12-30-2014, 08:23 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: PT 11.3 is a nightmare!!
Help us Help You - READ THIS Before Posting!
http://duc.avid.com/showthread.php?t=300050
What is your OS version? Computer? RAM? Are your plug-ins in the plug-in folder? What interface are you using? What hardware driver?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 12-30-2014, 08:29 PM
Southsidemusic's Avatar
Hey
That is a nightmare
Have you tried to delete preferences and databases as the plists are in that step and then PT11 will reload all your plugins. It takes a few minutes depending on how many plugins you ha e but its worth a try. It only does that long reload once after you trashed prefs and dbases.
Again sorry to read this as it's a real downer when these issues occur
Best Regards
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-31-2014, 02:57 AM
::F-L-E-X::'s Avatar
::F-L-E-X:: ::F-L-E-X:: is offline
Had this happen to me a few times...
Unfortunately, un-installers (or lack of), seems to be an unwelcome growing trend with many software devs.
Unofficial word is that it's sufficient to simply trash the PT app itself, but officially Avid's guidance : http://avid.force.com/pkb/articles/e...uninstall-PT11 , implies the need to trash the following :
Mac HD/Library/Application Support/Avid/"Audio"
This is what removes your 3rd party plugs from Pro Tools. Why this is deemed necessary is beyond me, (unless these instructions are intended as a permanent uninstall - but perhaps this should be made more clear by Avid).
Only solution I found was to re-install 3rd party plug-ins.
Old 12-31-2014, 08:53 AM
Thanks for the replies. I'm running a 3.4 ghz imac with 32 GB RAM. I did manage to get back to PT 11.2.1 and got all my 3rd party plugins reinstalled and recognized by PT. Has anyone else had the issues I mentioned with 11.3? The bounce to disk still doesn't work right (crashes with an AAX-9173 error), and recording is impossible. Tracks arm but when I arm the transport, the transport remains static, with the "waiting for midi" alert message even though I don't have the F11 key engaged in midi prefs. The transport will not start it just remains at record ready.
More PT 10 nightmare notedmusic Windows 18 05-22-2012 11:04 PM
Nightmare or not ! French links 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-24-2008 03:34 PM
OMS nightmare HELP drumbar Pro Tools TDM Systems (Mac) 4 01-22-2003 11:30 PM
HD Nightmare !! Allan Speers Pro Tools TDM Systems (Mac) 9 08-03-2002 10:00 AM
PCI BUS NIGHTMARE! byteme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-10-1999 06:16 PM
