Old 12-07-2013, 06:54 PM
fourfourateighty fourfourateighty is offline
Default PT 11 download okay, but edit issues...
Got a few tracks recorded, but when i went to edit, found that the quantize "apply" doesn't do anything, and i seem to be missing some plugins. I think I have been through the myriad optimization steps, and "troubleshooting" doesn't say anything about these issues. Should I re-install?
Old 12-08-2013, 12:12 PM
joachim's Avatar
joachim joachim is offline
Default Re: PT 11 download okay, but edit issues...
Maybe, first, provide detailed information about what you have done and about your set up.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 12-08-2013, 01:41 PM
Southsidemusic's Avatar
Hi
Welcome to the Forum
I would first start by checking that you have installed the Virtual Instruments and Air plugin file in your Avid Account as they are a separate download from the PT11 installer.
Secondly when quantizing a midi track / virtual instrument track you need to highlight the part on the track you wanna quantize and then click apply and that should definately quantize that part. If you are talkng about quantizing a audio file you need to look into using elastic audio and such funtions.
Post back so we k ow what you experienced with this.
Best Regards
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-08-2013, 04:26 PM
the setup is sandra-pasted in my public profile - hope that works. I have used ProTools 8 "Essentials" so, though anticipating a steep learning curve, I'm not completely spastic about how this "ought" to work. After PT11 loaded from cd, found I could not record - somehow I figured out that I had to update my interface driver. Accomplished that but now I can't find any reason for the missing plugins and the quantize malfunction. I was about to re-install but considering the hoops jumped through just to get here it occurs to ask for help may be wiser.
Old 12-08-2013, 04:31 PM
Yes as i said, the plugins and virtual instruments are a separate installation and if they are on a CD or not they need to be installed as you won't have all the included pligins in pro tools so start by fixing that.
And the sandra report desn't list any external or internal drives or your interface so please post a complete sandra report with your harddrives and interface connected and post that here.
We don't usually go to members public profile pages to find this info,
Best
Chris
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 12-08-2013, 08:57 PM
Thanks very much for your responses, Chris. I found the Air Collection and the Virtual Instruments was included in that download. (Haven't been back to see if the plugins are showing up yet - but I'm optimistic) I will take some time with elastic audio to figure out the quantize function. I made sure everything hooked to the computer is on and ran another sandra report, included below. Some of it is unintelligible to me, if you see something out of whack, I'd appreciate your input.
SiSoftware Sandra
ID
Host Name : Rob-PC
Workgroup : WORKGROUP
Computer
Model : OEM System Product Name
Serial Number : System Ser**********
Chassis : Desktop
Mainboard : ASUS M4A89GTD-PRO/USB3
Serial Number : 1085303********
BIOS : AMI (OEM) 1703 11/16/2010
Total Memory : 8GB DIMM DDR3
Processors
Processor : AMD Phenom(tm) II X4 970 Processor (4C 3.51GHz, 2GHz IMC, 4x 512kB L2, 4x 6MB L3)
Socket/Slot : AM2r2/AM3
Chipset
Memory Controller : AMD RS780/880 Host Bridge 2x 2GHz (4GHz)
Memory Controller : AMD F10 Athlon 64/Opteron/Sempron HT Hub 2x 2GHz (4GHz), 8GB DIMM DDR3 1.34GHz 128-bit
Memory Module(s)
Memory Module : Kingston 9905471-009A00LF 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : Hewlett Packard HP vs15
(1600x1200, 14.6")
Video Adapter : NVIDIA GeForce GT 430 (2CU 96SP SM5.0 1.4GHz, 128kB L2, 1GB 1.4GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GT 430 (96SP 2C 1.4GHz, 128kB L2, 1GB 1.4GHz 128-bit)
Compute Shader Processor : NVIDIA GeForce GT 430 (96SP 2C 1.4GHz, 128kB L2, 1GB 1.4GHz 128-bit)
CUDA GP Processor : NVIDIA GeForce GT 430 (96SP 2C 1.4GHz, 128kB L2, 1GB 1.4GHz 128-bit)
Storage Devices
WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (C:)
WDC WD1002FAEX-00Z3A0 (1TB, USB2/SATA600, 3.5", 7200rpm) : 932GB (E:)
HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+-RW, CD-RW) : N/A (D:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Storage (E:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, USB2/SATA600, 3.5", 7200rpm)
Hard Disk (C:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm)
Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+-RW, CD-RW)
Peripherals
LPC Hub Controller 1 : ATI (AMD) IXP SB600/700/800 SMBUS Controller
LPC Hub Controller 2 : ATI (AMD) SB700/800 LPC host controller
LPC Legacy Controller 1 : T2 87-21
Audio Device : ASUS IXP SB600 High Definition Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Device : EVGA GeForce GT 430
Audio Codec : nVidia 0014
Serial Port(s) : 1
Disk Controller : ATI (AMD) SB700/800 SATA Controller [AHCI mode]
Disk Controller : ASUS JMB361 AHCI/IDE
USB Controller 1 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 2 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 3 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 4 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 5 : ATI (AMD) SB700/800 USB OHCI2 Controller
USB Controller 6 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 7 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 8 : ASUS Renesas Electronics USB 3.0 Host Controller
FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller
SMBus/i2c Controller 1 : ATI SB800 SMBus
Printers and Faxes
Printer : EPSON WF-2540 Series (360x360, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP Deskjet 5400 Series (1200x1200, USB, Colour)
Fax : EPSON PC-FAX driver (203x203)
Scanners and Cameras
Scanner : Hewlett-Packard HP Officejet 6500 E710n-z (NET) (Scanner, USB)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet)
Wireless Adapter : NETGEAR WNDA3100v2 N600 Wireless Dual Band USB Adapter (802.11b (HRDSSS), WEP n-bit, 11Mbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 12-09-2013, 06:45 AM
My plugins have made their entrance - thank you!
Rob
Old 12-09-2013, 09:09 AM
Rob
Thats Great! I am glad you found them.
Best
Christopher
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 12-11-2013, 06:48 AM
Chris, found elastic audio - quantize working - thanks for the help!
Download issues still ongoing? danander11 Pro Tools 9 0 12-12-2010 06:25 AM
PT 8.0 Download issues Aaron Troughton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-18-2010 12:22 AM
Download Issues On AIR Blog RussUK Virtual Instruments 2 03-07-2009 04:40 PM
Edit Pack USB issues TimDay ProControl, Control|24, Command|8 4 08-03-2002 11:23 PM
5.1.1 download issues in the UK redleader 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-29-2001 09:18 AM
