Let me get this straight, do NOT power an mbox 2 pro from it's power adaptor?
So never power the mbox 2 pro from it's own power adapter when running on a firewire bus with it's own power. I would've thought the power adaptor would help the mbox 2 pro to run better.
Re: Let me get this straight, do NOT power an mbox 2 pro from it's power adaptor?
Is that a question or the answer already?
Anyways, I'd say the General Troubleshooting Thread is pretty clear: Quote:
Well, why???
iMac 27 inches , late 2012, Quad-core, 8 GB ram, Fusion Drive, 3,4 GHz Intel Core i7, MacOs Mojave 10.14.6, Focusrite Saffire Le, thunderbolt adaptor, 800/400 FW cable. |
Short answer: Because!
Longer answer: Imagine feeding a light bulb with more power than it actually needs. It can't say no, can it? Now think of doing that to your precious MBox 2 Pro or whatever. I guess with a little more budget Digi could have made the MBox say no. But obviously it can't. Although it's quite possible that your MBox survives the procedure the greater amount of power could make some internal ICs go nuts. Hence the errors. You guessed it already: I am not an electrical engineer myself.
Mac Pro 8-core 2.26 | 6 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8 MacBook Pro i5 2.3 | 4 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8 |
Hi bfx!
I'm not an electrical engineer too but I don't think you're injecting more current in your MBox2 Pro with the power supply and the firewire cable plugged in at the same time. The device can be only powered by one and only one source of power. One should disable the other, I presume. So to me, if there is a reason, it's not that one. Anyway, using the firewire OR the power supply power, not both at the same time, is certainly what we call common sense!
Yep but certainly not the one you're giving -- no offense!
IMO bad electronic engineering practice. (I'm an EE)
One supply should cancel the other electronically. If both connected, external should be used. Also the led feedback is counterintuitive. If the power comes from the adaptor, the led lights green (green is associated with "OK"). If the power comes from FW, the same led is Orange (orange="warning"). If both are connected, the led goes green again (OK) but it's not OK!!! IMO it should be green when powered either way and flash orange when both connected at least. Another flaw that caused me MAJOR headache is that when I first connected the Mbox 2 PRO to the computer, it apparently went through an automatic firmware update during which NO signs of life whatsoever are given. The power led was OFF (although connected to power) and I thought the unit died in my hands the first day. Also, on my unit, one of the pots is much harder to rotate than the others, apart from being highly uncomfortable to use... Really un-pro design... |
Now I am interested – why certainly not?
Need a replacement MBox 3 Pro power adaptor | anackman | Pro Tools 10 | 2 | 01-14-2013 09:30 PM |
Would this UPS (Uninterrupted Power Supply) protect and power my gear? | D_Japan | macOS | 4 | 07-24-2011 04:23 PM |
My car as an studio: Will the Siig laptop firewire run without power adaptor? | AussiePablo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-08-2010 05:20 AM |
Mbox 2 power consumption? How much of a power load is this | spaids | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-30-2007 06:27 AM |
do i have to buy "european" version of digi002, or use "american" with power adaptor? | stoka | General Discussion | 3 | 10-04-2002 05:28 AM |
