Restore dae files?
hello!
My last thread was about an end of stream problem. I managed to solve that, but in my desperation I think I removed all plugins using the digidesign utility tool. Is there any way of restoring these without having to uninstall/reinstall all the plugins? The plugins are still installed, but I think the dae-files are gone =/ Thanks in advance, again / Jocke |
Re: Restore dae files?
If you used the Tech Support Utility you should have the option to move all the plugins back to the regular plugin folder, You can always simply drag them manually from the Unused Plugins folder to the Plugins folder.
If you actually trashed the DAE file I think that you will need to re-install PT unless you can drag it back from the recycle bin. If your worried about the DAE "Prefs" file don't. The Prefs file will get rebuilt when you relaunch Pro Tools. the same holds true for the Digidesign Database files on each logical drive. Hope that helps
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
corrupted Pro Tools session files, help restore to their original .ptf/.pts format? | sophiea | Pro Tools TDM Systems (Mac) | 1 | 03-20-2015 06:34 AM |
Restore Corrupt Audio Files? | U2502 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-24-2007 10:54 AM |
Pops and clicks on files from Retrospect restore | KenSluiter | Pro Tools TDM Systems (Mac) | 4 | 01-04-2004 04:01 PM |
How to restore files from Digi's old DATa backup utility? | Michael Klinger | Pro Tools TDM Systems (Mac) | 3 | 09-29-2001 12:15 AM |
My Audio files were deleted!!! What software to buy to restore the files.... | lucio matarazzo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-22-2000 06:45 PM |
