Anybody experience THIS ?? ( not Power Harness )
hey guys -
anybody experience this : I'll be playing a session - or recording - and my cinema screen goes blank , computer seems to go to sleep , and PT crashes. Hitting spacebar awakens the Mac but PT is quit I have 7.1 w/ the MP Toolkit running on a Dual 2.7 ( lotsa ram ).. I usually record at 44.1 and can run 25 tracks or more w/ plenty of plugs as well - and still keep a very low buffer to keep latency down - like 128, or even 64. I never have problems w/ my OWN sessions But I was mixing a friends session ( 48 / 24 ) and the above situation happened for the first time. Doing guitar overdubs for another friend's session today ( also 48K ) the same thing happened twice shouldnt I get a " Increase Buffer" notice or something - it's just crashing !! I was thinking this may be the dreaded Power Harness - but typically "communication" w/ the 002 is perfect and my serial # ends w/ G ( which means it has the latest PH ) any ideas ?? The crashing goes away if I raise the buffer - BUT I would like to be TOLD to increase the buffer if thats really the issue. I fear its something bigger |
Re: Anybody experience THIS ?? ( not Power Harness )
Check the power saving settings and see if your computer is set to sleep. Never set it to sleep.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Thats not it - but thanks
It's EXACTLY what it's acting like though ( computer sleeping ) but it is set to Sleep NEVER |
Do you have screen saver disabled?
www.barnabas.com Barnabas MultiMedia |
ok.. OBVIOUSLY I can do that
But if it hurts when you push on your leg and you know there's a problem - you dont really want or need the DOCTOR to say " Well..then dont push on it" !! You wanna FIX the problem |
Setting the buffer to the correct size for the session is NOT a problem.
From the manual: "The DAE Playback Buffer Size determines the amount of memory DAE allocates to manage disk buffers. ?DAE Playback Buffer Size settings lower than Level 2 may improve playback and recording initiation speed, but may make it difficult to play or record tracks reliably with sessions con- taining a large number of tracks or a high den- sity of edits, or running on slower or heavily fragmented hard drives. ?DAE Playback Buffer Size settings higher than Level 2 will allow for a higher density of edits in a session or a higher track count when using slower hard drives. However, a higher setting can also cause a time lag to occur when starting playback or recording, and result in a longer au- dible time lag while editing during playback. If Pro Tools needs more system memory for the DAE Playback Buffer, it will prompt you to restart your computer.
Thanks Park -
I will look more closely into that. Do you think having that set incorrectly would cause my Mac to just essentially go to sleep w/ out a "Pro Tools quit unexpectedly" window popping up ?? I do know it happened w/ a buffer of 64 ( level 2 DAE ) , NO plugs at all , and one stereo bed track imported into a new session and while recording a new gtr track in the middle of playback of a freshly recorded take , the screen went dark and the computer's fan went off, etc... hitting spacebar awoke the screen - but PT hadnt quit , although the session had crashed |
002R Faults + power harness + no phantom power | DaveSB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-26-2009 01:10 AM |
002 power supply/bad power harness? please help :( | djkiller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-07-2005 08:04 PM |
002 rack power harness power suplly issue | rockstah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-06-2004 11:04 PM |
002 Power harness... again! | JDL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-09-2004 04:08 AM |
BAD POWER HARNESS/POWER SUPPLY!!??HELP!! | snuffacation | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-11-2004 03:03 PM |
