Can only see L channel in 5.1 Multi Mono plugin
(see pic+red circle) when I select the Center channel, it jumps back to Left. When I reboot it works fine for a bit, then goes back to this behaviour.
Moving it to another location doesn't fix it, neither does unlinking the channels. Izotope Dssr plug seems fine, Waves and Avid and others do this..ideas ? PT 2020.4, Mac OS 10.14.6, EuCon 20.1.0.50 L channel only.jpg Last edited by Benny Mouthon; 04-30-2020 at 04:33 PM. |
Re: Can only see L channel in 5.1 Multi Mono plugin
Hi.
I'm having the exact same problem and its driving me nuts. I can't use a DeEsser on a 5.1 stem since I cannot see the centre channel! /martin
Mac Pro late 2013 3,5 GHz 6-Core Intel Xeon E5 64 GB 1866 MHz DDR3 Mac OS 64 GB 1866 MHz DDR3 BlackMagic UltraStudio Express Pro Tools Ultimate HDX 2020.9 S3 - Dock - PT Control |
Not a solution, but a possible temporary work around...
Try option (Mac) clicking in the channel drop down. This should open up a separate GUI instance of the plugin for each channel.
Scott Gatteño |
I believe it’s eucon which is forcing the left only to be shown. I have had this behaviour in the past.
A fix is to click on the button above the ‘L” so the channels aren’t connected. Rich. Sent from my iPhone using Tapatalk
Richard Spooner Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM. www.spoonsound.com |
Thanks for the suggestions.
It's not Eucon related (at least not on my MBPR!) and the strange thing is that when I try to switch channels on my MacBook Pro Retina running PT Ultimate HDX in Native mode it works as it should! I will test your suggestions later today when I'm in front of my studio set-up with the HDX hardware connected. Thanks.
And its solved (sort of)!!!
Spoons - your probably absolutely right! Quitting Eucon makes it possible to select any of the six channels in a multi-mono plug in. And the other tip (originalscottyg) using Opton-Clic on the channels also work - though a bit clunky! Thank you both for your help and now I will start a thread in the S3/Eucon forum to get them to fix it. /martin
Seeing this as well. I can select the C channel on a multi-mono plugin, but as soon as I touch a knob or fader on the S6 to control the plugin, it jumps back to showing L. Very annoying when adjusting parameters on the Cedar, where I need to see the C channel. Only workaround I have found is to create a window layout, then the plugin stays with the selected channel.
Espen
IMDB |
Multi-channel vs Multi-mono plugs on 5.1 tracks | geitz | Post - Surround - Video | 0 | 06-08-2007 09:06 AM |
Multi-channel vs Multi-mono plugs on 5.1 tracks | geitz | Pro Tools TDM Systems (Mac) | 0 | 06-07-2007 02:54 PM |
multi-mono versus mulit-channel plugin | pietro79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-21-2007 02:33 PM |
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs | citi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-13-2002 11:08 AM |
Multi Mono vs Multi Channel Plugins...Just curious... | Mr T | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-18-2002 09:46 PM |
