Update 11.1.2 to 11.3
Hi there,
do I have to completely remove the 11.1.2 version before updating to 11.3? Or will Pro Tools automatically udpdate the old version when I run the installation file? Regards Tom |
Re: Update 11.1.2 to 11.3
Avid suggests uninstalling the older version of Pro Tools 11 before installing the latest version.
http://akmedia.digidesign.com/suppor...uide_83689.pdf
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Hi Benoni,
will I have to reinstall all plugins again after I install the PT 11.3 version or will they all be recognized by the new version? I am asking because I work on several projects at the moment and I am not sure whether I should make the update now or better do it the safe way and wait until the projects are finished. |
You don't have to uninstall your plugins, just Pro Tools. They will still be there in the latest version.
If you have a deadline though it's usually best to finish what you are doing before updating unless there is a specific feature/bug fix that you just must have to finish your work.
And backup first before doing any upgrade/update/install/uninstall using Acronis True Image Home or similar.
Cheers,
HD Native cant Update Firmware after installing PT9.0.5 Update | Aditu | Pro Tools HDX & HD Native Systems (Win) | 72 | 11-27-2012 03:57 PM |
10.3 Update - Windows shutdown issue has returned. Update at your own risk. | crm0510 | Windows | 14 | 09-19-2012 01:50 PM |
10.5.6 update. Is it safe to apply the system update from 10.5.5? | SBCCMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-02-2009 02:27 AM |
Windows Update Vs Apples Software Update | sunburst79 | General Discussion | 2 | 07-14-2007 06:40 AM |
What is this Apple Update? Hard Disk Update...ver 1.0 | McMasters | Pro Tools TDM Systems (Mac) | 1 | 06-30-2003 05:56 PM |
