Bass amps
I was just trying to get everyones opinion
I am buying a new bass amp cept I dont know what to get I have narrowed it down to 3 heads Ampeg stv3 pro, SWR 350x, and a Mesa Boogie Walk-about I am in a jam/groove band like phish or the Disco Biscuts What do you think ~Mike |
Re: Bass amps
Definitely go with the SWR... Absolutely.
Re: Bass amps
I've had good luck and great sounds with the Ampeg stuff! I used a 3 pro for quite a few years before I went with the 4 pro for more power.
If you go ampeg, make sure you get a newer one with a transformer on the xlr output to help eliminate buzz or you'll need a di box. And Sean,.... send your old bass teacher an email since you dissed him! [img]images/icons/wink.gif[/img] Ha!
www.DavidKarns.com 002R, AMD2500+ Gear List: http://www.davidkarns.com/studio.html |
Re: Bass amps
Three letters-
SVT I have used a 3 pro for years. I used to use an SVT classic head, but it was a bit large to lug around. I also have used the 4 pro, but i think the 3 pro sounds better. not sure why, it just does. of all the SVT choices, I have found the 3 pro to be the most versitile, and i think its a good choice if you go with ampeg.
+CORPORATE WHORE+ www.8mmOverdose.com www.Tondra.com www.UnderworldEvents.com www.JagerMusic.com www.MonsterEnergy.com |
Re: Bass amps
I had the chance to test every Ampeg there was (in 1999).So i grabbed a B-2,because i wanted this 'round' and fast bass sound along with tight mids.(It's a fender vintage precision '57 BTW).
Well it's the best amp i have ever played with. I also checked some trace-elliots,but i didn't like the fact that,every bass you plug-in,sounds the same. |
Re: Bass amps
Hello,
I have used an SVT II since 94. This is an awesome amp complimented with Eden cabs. The xlr DI out is very clean and I have used it for both recording and live. I previously used a trace elliot and also have to agree that all basses sound the same. I also use a bass pod pro when looking for different modelled sounds for recording but I tend to record the svt along with it. It just adds such a full sound. Hope this helps. cheers. |
Re: Bass amps
I don't think you can go wrong with either the ampeg or the SWR. I have tried both and while I wasn't as impressed with the ampeg as everyone else, I liked both. Both of them can be pretty thumping when they need to be. [img]images/icons/wink.gif[/img]
Re: Bass amps
Man, all 3 are nice. I personally like the Ampeg.
Re: Bass amps
I like the ampeg for rock and the swr for jazz, but I haven't played bass in a while though....If I remember right, the wierdest thing with the ampeg was that it sounded completely different in every venue, where as the swr seemed a little more consistent. But when the svt is rockin', man it's rockin!
Cavell Studios |
Re: Bass amps
If I had a nickel for every SWR I've fixed over the years.....PSU caps mostly...I'd have a lotta nickels.
SVT. Proven rock solid. Hope this is helpful. |
Record bass w/ Ampeg SVX - just plug bass into MboxPro or go in w/ DI like SansAmp? | Squid Vicious | Eleven Rack | 10 | 12-31-2012 01:46 PM |
Mbox 3 Pre amps vs. External Pre amps? | evanbgrove | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-10-2011 05:21 AM |
Mbox 2 pro... Pre Amps (vs) 003 Pre... Amps | Norm Mix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-24-2009 02:37 AM |
Bomb Factory/Bass Pod for Bass Tones? | accameron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-14-2002 05:21 PM |
Bass Pre-amps | DJ Burt | Tips & Tricks | 28 | 06-07-2001 10:01 AM |
