Old 03-02-2003, 12:28 AM
j20056 j20056 is offline
Default MIDI problem with Esoundz drum library for SampleTank
I bought the ESoundZ drum library for SampleTank.
The problem is that standard MIDI files with drum patterns don't play correctly on it.
The standard MIDI frmat for drums specifies that the kick is on C2, the sanre D2, etc... All the SampleTank drum libraries that came with XL follow the specification, and play perfectly with DrumTrax patterns, but none of the Esoundz.
Has anyone seen this problem? Short of shifting notes by hand, which is a massive pain, is there a way to proceed?
IK Jason, is there a way to change a SampleTank preset to assign the drum components to different notes?
Other options?
Digi002 Rack
Mac Pro 8-core 3Ghz
8gb RAM
3X 500GB 7,200 SATA DRIVES
OSX 10.5.7
PTLE 8.0cs3
Problem opening MIDI session with SampleTank tracks... orazio MIDI 0 08-14-2007 07:18 PM
Midi Controller / SampleTank 'multi-voice' problem Brandon Klopp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-10-2007 07:57 AM
midi drum pattern library ? tantejo Tips & Tricks 4 01-10-2006 05:47 AM
I want a good drum library to use for PT 6.7 benthepianoboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 12-20-2004 06:22 AM
newbie question re: midi, drum tracks, sampletank... genebadd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-01-2003 11:33 AM
