Old 06-16-2021, 07:13 AM
garret garret is offline
Default Panpositions flipping on S4 Master module
Hey
Weird one here. In my local options I have Pan as the "function and knob page selected on attention change" and EQ for the backup.
When I am on a mono track everything works as expected and the front panner appears on the bottom right encoder on the master module.
If I then click on a 7.1 track (which has no panner) it switches to showing the eq on that track. So far so normal!
Now if I then click back on my original mono track the front panner now appears on the bottom left encoder of the master module! Basically a mirror flip.
If I then click on say a VCA and then click back to my track it will be correct again.
It feels like a bug to me. Any ideas? I can provide a video if you like
Thanks
Garret
IMDB
Old 06-17-2021, 07:51 AM
EddieJones's Avatar
Default Re: Panpositions flipping on S4 Master module
We just tried this with the current beta 21.6 and don't see it....but it does happen in 20.11! Release is set for 29th June
Old 06-17-2021, 01:50 PM
Aha! Thanks for the update Eddie!
IMDB
Master Meter Module and PEC / DIR GCScott Avid S4/S6 5 02-03-2021 04:26 PM
Master module Appset blank Mishabou Avid S4/S6 9 04-04-2020 06:43 PM
EQ and DYN not displaying on knobs or Master module pikejono Avid S4/S6 9 08-02-2019 06:33 AM
Master Module Won't Boot hixonjames Avid S4/S6 6 02-09-2018 12:01 PM
Master Module FAN NOISE rcutz Avid S4/S6 11 07-29-2015 06:39 AM
