  #41
Old 01-06-2020, 04:31 AM
LDS LDS is offline
Default Re: Pro Tools 2020.1
Originally Posted by BScout View Post
I've been using 2019.12 since the moment it was released. The problem is Catalina+2019.12. I have no intention to go to Catalina until all the codecs are supported again because it would cripple workflow.
And his point is MXF is all we need on Catalina to work with video. It's right there in his post to Mark.
No need to guess.
Are you suggesting that you would recommend a different wrapper to MXF to work with video under Catalina?
What a sad state of affairs it must be when even a simple act of trying to make the most of the ****ty software updates avid gives us is misconstrued as an insult. If you don't like Catalina + 2019.12, that's great... but for some users it isn't the problem. It is the only solution. So, by all means exercise tunnel vision and contort posts in order to take offence - as long as users are misdirecting their anger at each other rather than Avid, all will be ok! But do so knowing that next time someone asks you about video on Catalina, you have the answer...
"All you need to work with video in Catalina is convert your video to MXF wrapper instead of the MOV." Avid even made a neat little grid too, if people don't understand you. http://avid.force.com/pkb/articles/c...e-Type-Support
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
  #42
Old 01-07-2020, 08:13 AM
daeron80 daeron80 is offline
Seriously, though, I'm in bad need of PT First being made Catalina compatible. My boss, who sometimes records remotely with us via First, was just given a new MacBook Pro by IT because his old one was dropping out of record a lot. Of course, the new MBP can't run anything earlier than Catalina, so now our workflow is totally broken.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
  #43
Old 01-07-2020, 01:28 PM
off the wall's Avatar
off the wall off the wall is offline
PT First isn't at the same code level as 2019.12? I don't use it so I don't know.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
  #44
Old 01-07-2020, 03:28 PM
Eric Lambert's Avatar
Are the newest MBPs hardware-limited to Catalina? Typically, even a new laptop can be wiped on Day One so that an older OS can be installed. Maybe the new MBPs won't allow it. That would put PT owners who need new computers in a tough spot.
  #45
Old 01-07-2020, 03:58 PM
Sardi Sardi is offline
They were released post Catalina so can’t roll back to anything earlier unfortunately.
Most PT owners aren’t in a tough spot anymore since the 2019.12 release. The person with the new laptop is trying to run PT First which going by his experience, doesn’t seem to be at the same version release as the full PT app. Not sure. Don’t use PT First.
  #46
Old 01-07-2020, 07:18 PM
Anthony Jr.'s Avatar
Anthony Jr. Anthony Jr. is offline
To be honest, I moved to MXF video in ProTools about a year ago and it's been so much better to use than any other supported codec in the past. Probably because it's Avid's IP.
I'm mostly confused about public thoughts about converting their current video deliverables to AVID's codec. Works very well.
Mac Studio M2 Ultra / MacBook Pro M1 Max / Ventura / Apollo 8XP / FabFilter Forever
  #47
Old 01-08-2020, 09:42 AM
Sugarnutz Sugarnutz is offline
I don't care! My big Mojave rig runs 2019.x Ultimate just fine and I'm currently building a z97/i7 hack running Mavericks and PT 10.3.10. It's running very well with Thunderbolt Native and hope to have my Magma/HD6 hooked up and rolling by the weekend. Also my PT Ultimate update plan expired in December, NO MAS! I make records, not movies (but I have).
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
  #48
Old 01-08-2020, 10:39 AM
YYR123's Avatar
YYR123 YYR123 is offline
Is this deja vu? I come back to the forum because I purchased an update b/c avid twisted my arm.....
and I see the same posts as 5 years ago......
The new update won't run on the latest apple release
I just got a new computer and I can't run the older software release...
OMG literally the same post for the last (more than) 5 years.....
I love apple products too, but this yearly cycle needs to stop.....they are narcissistic about their software......it's really the gist of the problem that users have....
Daniel
  #49
Old 01-08-2020, 11:07 AM
JFreak's Avatar
JFreak JFreak is offline
Yea. How come people cannot take a guess if you buy shiny new hardware that only runs latest macOS then maybe you also need to have most current PT as well
Janne
  #50
Old 01-08-2020, 11:50 AM
Why couldn't you wipe the drive and install Mojave? We've done that with new computers many times (not Mojave) when the pre-installed OS wasn't yet compatible with PT.
Pro Tools reinstatement plans axed from Jan 1st 2020 noiseboyuk Licensing & Accounts 85 04-27-2022 06:11 AM
Pro Tools Perpetual License with 1-Year Updates and Support (until 12/2020) smokeynyc Buy & Sell 8 02-23-2020 04:02 PM
Avid drops Pro Tools reinstatement on 01-01-2020 Delta Music Belgium Licensing & Accounts 6 11-27-2019 03:19 PM
Avid announces Pro Tools 2020, 2021 and 2022! off the wall Pro Tools 2018 2 04-01-2019 08:50 AM
JV 1010 or XV 2020 petter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-17-2006 09:19 AM
