#341
Re: Waves Studiorack
Thanks much ghostwriter. propower- the fan is just a hair louder than an avid io, or maybe about the same. It is a computer essentially afterall so it is pretty impressive how quiet they've made it. If it's important for you to have the io in the tracking room and you need some dsp I might recommend getting a DLI and separate server that can be put elsewhere on a cat5e or cat 6 run for the same reason I don't like having the avid io's near microphones.
#342
Looking at this I think this is unacceptable solution for many, including me:
https://www.youtube.com/watch?v=R3S0wd7LcJU Waves, please make AAX DSP versions for us. We will pay you for that. We will not pay you for your Digigrid boxes because they are step backwards from your TDM versions. You used to make something really good - Waves TDM plugins.
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
#343
The buffer setting in Pro Tools 11 only applies to tracks that are set to input. When using a studiorack, those tracks completely bypass that buffer so its setting is completely irrelevant. There's also no reason to not run studioracks that aren't being used to record on the host and not the server. Virtual instruments that don't run on soundgrid are the only situation where the buffer setting would matter. PT 11 does not work at all like TDM. People are comparing apples to oranges by comparing HDX or studiorack to TDM.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson Last edited by Bob Olhsson; 09-30-2014 at 10:19 AM. |
#344
In reality I see this as a small bonus of the system...seeing that as an HDX card user you already have a solid offering for low latency AAX DSP plugins... softube, BX, McDSP, Avid... not a plethora, but solid. and waves plugins anyway fit more into the "mix category" rather than creative like something such as sound toys does... I'd be way more interested in pressuring them to do AAX DSP as their plugins aren't really covered by anything in the AAX DSP realm. For me, the networking and routing possibilities of the digigrid system is where the MEAT is... it is incredibly cool and easy to route audio across a LAN with digigrid. Of course this doesn't fit everyone's needs... or at least not everyone realizes it. The DLI is affordable enough that you can create a vast multi room system for very little $. Now that is cool. That being said, sure it would be nice if I could load up GTR as an AAX DSP plug. But its not looking like that is going to happen. What would be effing great though is if other developers who have passed up AAX DSP started porting their plugs to sound grid... us AAX DSP users would have a means of accessing a whole new realm of low latency processing with some minimal workaround by jacking into digigrid. But that remains to be seen. |
#345
If that happens, DigiGrid/SoundGrid will have life inside the studio. There will not be a need for native users to upgrade to the latest and greatest computer as all the processing can be handled via Waves DSP. We shall see if any/many aax-native only companies join in. I don't count Plugin Alliance. They will code plugins for a coffee maker if that coffee maker used plugins
#346
Is that the one George Clooney advertises?
#347
#348
When using digigrid in SGP mode, HDX does not apply at all. it is not in the equation, you don't use it. The DLS connects directly to the Mac via ethernet. If this doesn't clear it up, then I'm not quite sure what you are asking. |
#349
#350
Waves license not found after Waves update | Talisker | Pro Tools 10 | 5 | 03-26-2014 09:14 AM |
Keep Loosing all Waves presets from Waves tool bar!! | crizdee | Pro Tools TDM Systems (Mac) | 4 | 03-12-2010 02:59 PM |
Not enough space on Waves only ilok to download Waves update 7 | crizdee | Pro Tools TDM Systems (Mac) | 38 | 11-09-2009 05:19 PM |
Plugs Advice: Sony vs Waves - Sonalksis vs Waves? | John J. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-08-2005 01:31 PM |
WAVES Protools7 update and Waves tech support | x9blade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 11-11-2005 06:24 PM |
