Old 06-16-2010, 06:23 PM
gsilbers gsilbers is offline
Default How are u guys capturing video?
if u have to capture from tape which i dont think it happens a lot anymore.
do you use PC and if so which program?
can u record straight into quicktime pro (PC/MAC) and if so how reliable is it?
thx
Old 06-17-2010, 08:28 AM
Sean Russell Sean Russell is offline
Default Re: How are u guys capturing video?
Probably better asked to the Post Pro crew. I myself have never needed to do it for PT (luckily). When I do have to capture (mostly for personal stuff), I use an ADCV100 Canopus box.
... but does it help the chorus?
Old 06-17-2010, 08:35 AM
Studio Studio Studio Studio is offline
I simply don't accept tapes anymore. Saves me a lot of time. It's little effort for a picture editor to just export the project to a quicktime file.
I'd use the Canopus 110 too.
Old 06-17-2010, 09:48 AM
slarrat slarrat is offline
Here, we simply use DeckLinlk HD ext III.
It works perfectly
Old 06-17-2010, 10:18 AM
audiobob's Avatar
audiobob audiobob is offline
When I did capture a few years ago I used a Canopus.
Old 06-17-2010, 10:19 AM
nucelar's Avatar
nucelar nucelar is offline
Some decks have i.link (firewire) outputs. Connect it to a pc or mac and you should be able to record the DV stream directly if it's SD. Only drawback: only two channels of audio get captured.
Decklinks are just perfect for capturing uncompressed straight off SDI.
As for software, we use FCP. It lets you capture in MJPEG-A format.
Old 06-17-2010, 10:54 AM
kptkarl kptkarl is offline
Capture, when necessary, into Final Cut via Blackmagic Decklink or AJA ioHD on Mac. If using Decklink they bundle a great app Media Express (Intel only) that may save one from buying into FC.
More and more we just receive Quicktimes. Although they seem to rarely send the correct specs :/ MPEG Streamclip is a must have in the toolbox.
Old 06-17-2010, 12:06 PM
artasarealthreat artasarealthreat is offline
You can capture video directly in Protools HD using a Sync I/O, an AVID video box or other video I/O (Cannopus, BlackMagic, etc.) and, obviously a VTR. You also need the Machine Control software. It can be a pretty expensive venture to do it this way but the process is far from becoming obsolete. Especially in television commercial workflow when many clients walk in with a tape and expect to leave with one once you've completed your portion.
Capturing Video in PC, working on MAC gsilbers Pro Tools TDM Systems (Mac) 9 06-19-2010 07:14 PM
Best Mac app for capturing video with Caponus? jahtao Post - Surround - Video 4 07-02-2009 06:15 AM
Capturing video. the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-28-2005 11:34 PM
Video Capturing Size Alagu Pro Tools TDM Systems (Mac) 0 03-02-2004 10:24 PM
capturing video pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-06-2003 12:11 PM
