Find Tempo?
I imported a drum loop that I sampled. How can I find the tempo of the drum loop? Or, can I stretch it to a specified tempo? I cant seem to get everything to line up in the editing window. Thanks in advance!
Re: Find Tempo?
There are a number of ways to do this...
All of them will require you to read the manual a bit, and probably watch a few youtube videos. If I just wanted to find the existing tempo of the loop, I would highlight the loop and use loop-play and a metronome to find it. Then I would set the tempo and use EA to align everything. Another way would be to use BeatDetective... Once you have found the existing tempo, you could align it to the gid of your NEW tempo. As long as it's not a severe difference, it should sound acceptable.. Or you could just set the tempo that you wanted, and use EA to align it to that.. (probably faster this way). Good luck.. Blessings!
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Find Tempo | tonicjeff | Pro Tools TDM Systems (Mac) | 9 | 12-11-2011 09:00 PM |
Can someone help me find Tap Tempo in PT7 LE | JacobIz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-26-2007 11:21 PM |
find tempo of wav????? | Livin' Proof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-31-2007 10:34 PM |
Cant find "tap tempo" function!!!!! | a kremer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-30-2007 04:03 PM |
How can you find out tempo | rcourell1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-06-2005 02:51 PM |
