Waveform display issue
I don't know if it was already a similar thread to this issue posted earlier. Here is a problem: when recording vocals and instruments I get large waveforms that go out of the tracks frames. Such waveforms are usually a case when the signal is too hot and overloaded, but in my case it even doesn't come higher than 0db and I don't hear any distortions or clipping in the sound. My card is Profire610, but I don't think that it can be a soundcard issue. My PT8 version is up to date. Maybe there must be done something with a tracks view in Edit window, but it looks pretty strange.
Re: Waveform display issue
maybe you have pressed the 'make waveforms larger zoom button' i dont know its real name but its in the zoom controls at the top right of the screen, to the right of the mode selectors grid/spot etc. Try clicking the down arrow on the waveform one and see if this helps..
I'm not sure if this is the answer but could be one possibility! |
Pretty strange. Sure you´re talking about Protools? Please post a picture of that? I really have to see it!
Thank you very much woodpigeonblue, it seems that I really pressed that button several times:) By the way, what is the true default view of the waveform, is it the max. zoom out? |
no worries sagas, i dont know what the default zoom is unfortunatley. maybe you could work this out by startiing a new session, recording some audio, taking a screen shot and check what level it is at by counting clicks down or up from the maximums? however, theres probably an easier more sensible way..
Double click on the zoom icon to change back to default
OK, thanks.
Waveform Size Display Issue Pro Tools 10 | Felix Andriessens | macOS | 4 | 12-06-2016 06:25 AM |
Waveform display issue | Ed K | macOS | 2 | 01-29-2012 04:01 PM |
Waveform Display | drummer9 | Pro Tools 9 | 2 | 11-27-2010 10:44 AM |
Pro Tools 7.4 LE Midi Note and Waveform Display Issue - Please Help | DGraham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-30-2008 09:36 AM |
waveform display | riozen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-05-2005 12:34 PM |
