Old 01-27-2009, 09:27 PM
PRS2300 PRS2300 is offline
Default HELP!!! -1407 error while creating audio files!!!
That is the Error......ive got about 12 tracks goin on PT 8 with mbox 2 pro and everytime i try and record on a track that message shows up anyone got and ideas????
Old 01-28-2009, 09:31 AM
DigiTechSupt's Avatar
Default Re: HELP!!! -1407 error while creating audio files!!!
I'm not turning up much on that error - is there any text that goes along with it?
Can you give us complete system details? Information on what we need to know to help you can be found in the Help Us Help You thread.
Avid Audio Tech Support
Support FAQ
Old 02-16-2009, 12:30 AM
jtsok jtsok is offline
I am getting the same error in a PTLE 8 session on a Mac using 002R.
when I create a new audio track, set the input, arm for record , it creates an error message when I hit transport to record. Error message reads "(-1407) while creating audio". Have deleted track closed session reopened tried again, to no effect. Also closed pro tools and restarted computer to no effect.
Never had this error before.
Old 01-30-2010, 08:40 AM
phame phame is offline
I am getting the exact same problem as jtsok. (-1407) while creating "audio files".
I recently deleted the fallowing Preferences folders after which i started receiving this Error.
DAE Prefs, com.digidesign.ProToolsLE.plist, and DigiSetup.OSX
After deleting these preference folders I began receiving the error message (-1407) while creating "audio files"
My Hardware:
Digirack 002
IMac
2.16 GHz Intel Core 2 Duo
2GB
Help appreciated!
Old 03-24-2011, 12:52 PM
clendn clendn is offline
I had this same problem... was working off an external hard drive. Could record existing tracks but could not add new ones and play or record.
I went to Disc Allocation and unchecked the "Custom Allocation Options" check box... then it started working. I think it has something to do with changing the directory under which audio files are stored. I hope this helps.
DAE error, -9073. PT creating bad files, help please! CCtzer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-15-2011 02:14 PM
ERROR -1407 Help??? PRS2300 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-20-2009 03:10 PM
ERROR -1407 (while creating audio files) HEEEELLLP!!!!! PRS2300 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-30-2009 08:04 AM
Heeelllp!!!! Error -1407 while creating audio files PRS2300 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-29-2009 10:54 AM
Error (-1405 while creating audio files) PRS2300 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-29-2009 07:52 AM
