Wav file pitch is slower after exporting.
I have a problem when exporting audio from PT LE 6.4. The exported wav's pitch is slower than the original audio recorded in the session. I am recording from DAT (PCM-R500) via SPDF into 001. The session is 44.1k & 16 bit. My clock source in PT is set to SPDF. My export settings are; stereo, 16 bit, 44.1k, convert after. Still sped up. I tried exporting with the DAT on and off which changed the pitch in PT due to the clock source (on sped up, off normal.) I tried exporting with the clock source set to SPDF and internal. I tried recording from the DAT via analog with clock source set to internal. Does anyone have any advise? Thanks T |
Re: Wav file pitch is slower after exporting.
You're probably clocking incorrectly. Check your DAT, it's probably set to 48k.
Thanks for the reply. I did check the sampling rate on the PCM-R500. The PCM-R500 does not have a selectable sampling rate for playback. However, it does detect what the rate is of the DAT I am playing. I believe this was my problem, the DAT was recorded at 48k and my session was 44.1k. Thanks again Slim.
tk |
.m4a file from iphone drops a whole key and slower tempo on import | fredmant | Pro Tools 10 | 9 | 12-25-2012 07:48 PM |
End of logical file whilst exporting file to disk | [email protected] | macOS | 0 | 05-10-2012 10:56 PM |
8.03 - playback slower & reduced pitch across 16 channels | sms1305 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 05-11-2010 03:51 PM |
Exporting Mono File to a Stereo Interleaved File | Mt.Everest | Pro Tools TDM Systems (Mac) | 3 | 03-13-2008 04:01 AM |
Bounced File Plays Back Slower | Luky7Music | Post - Surround - Video | 2 | 09-11-2004 07:40 AM |
