Master Mute Safe for Profile control surface
Dear Digidesign,
I just finished a tour with a major recording artist using a Profile, which I love. There is one problem with the desk which I'm hoping you will address. There is no "safety cover" for the master mute switch which is uncomfortably close to the VCA 8 mute button. Although I got through the whole tour without incident during a show, I did hit the master mute several times in soundcheck when reaching quickly for the VCA mute. I ended up taping a top from a water bottle over the switch to cut down the fear factor. Any chance you could engineer a cover into upcoming products? Any chance you could add a cover to existing desks? I doubt I'm the only guy who has had issues with this although I can't find any other posts. I'll look forward to all responses. |
Re: Master Mute Safe for Profile control surface
OR maybe the option to change that master fader into a selected channel fader.
Paul, maybe this will help you. I feed my PA using Matrixes and the pickoff point for the Matrix is post-insert, but pre-fade. I believe this basically disables the master fader for my purposes and the mute along with it. I started doing that because I'm driving my subs from an aux, and I was tired of people bumping the master fader if they thought pre-show music was too hot when I wasn't standing at the desk. Dave
David Stagl - Mixer | FOH Engineer http://www.staglproductions.com http://www.goingto11.com |
main.mute-safe (in general...) | xcx | VENUE Live Sound Systems | 6 | 01-22-2014 02:15 PM |
Profile surface VGA problem | yagga121 | VENUE Live Sound Systems | 8 | 08-23-2012 07:14 AM |
002 Control Surface Mute Button Broken/Stuck..! | Citrin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-26-2009 09:29 AM |
Mute Safe | Jim Roach | VENUE Live Sound Systems | 3 | 04-11-2008 02:13 PM |
how to make a midi track "mute safe" i.e. disable? | c-post | MIDI | 3 | 11-22-2004 08:30 PM |
