Quantize to grid bug?
Hello,
I´m having an extrange behavior with quatize to grid when grid being in Regions/Markers mode. It works or not depending of the zoom, if the zoom is close "quatize to grid" does not work but if you zoom out there is a point where it begins to work. It only happens with Regions/Markers mode, the other modes work perfectly. Thanks |
Re: Quantize to grid bug?
Are you in "samples" instead of ticks? If I understand your questions correctly, this is the problem. Change your view to ticks and it should look correct. It's come up many times here recently. Do a search for "grid" and/or "quantize" if you haven't already.
Buena Suerte |
Gracias Ginger, but changing to ticks makes no difference.
The problem is that when you select a region and select "Region>Quantize to Grid" or command+0 the region is supposed to align its begining to the nearest grid line. It works fine when grid is set to whatever mode but Regions/Markers, in which the selected region and the closest grid line (a marker or another region boundary) have to be "visually" very close each other for it to work. I say "visually" because if the region and the grid line are just 1ms apart but the zoom is close enough to see the sepparation in the screen "Quantize to Grid" doesn´t work, then zoom out several times and it will start to work. Pro Tools HD 7.3.1cs4 OS 10.4.9 Mac Pro |
Quantize to grid cause,s PT to crash | P,B,S | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-24-2013 10:22 AM |
QUANTIZE ALL WAPR MARKERS TO GRID, is this possible | P,B,S | Pro Tools 10 | 2 | 02-08-2013 01:16 PM |
Grid spacing and quantize. | east | MIDI | 5 | 10-30-2009 11:59 AM |
Elastic Analysis as Midi quantize grid???? | Dog BBQ | Pro Tools TDM Systems (Mac) | 1 | 08-06-2008 10:48 AM |
