PTMP & Sonar
I am running PTMP and Sonar 5.2 on a PC. I do all my live tracks in Sonar with an RME 9632 card. I use PTMP 7.3 for my mixing down and plenty midi with Xpand and Reason. I want to get a Mac to work PTMP on. I am looking at the new Mac Mini with the Core2 Duo 1.83 processor. Would the 5400 RPM Hard Drive be an issue? Since I would not be doing any audio tracks can I record to a USB drive? Would that Mac cut it?
Re: PTMP & Sonar
Sorry, you´re not very clear about what you actually want to achieve. so Quote:
5400RPM are also not recommended. But for playback you might get a stereo track or two. More important is that you don´t fill your system HD more than 50-60%. Hotfileswapping (autodefrag) needs a lot of space. For the second one, avoid USB drives whenever it comes to ProTools, it gives you nothing but trouble. highly disrecommended, no matter if you record or playback And the last one is also hard to tell if a Mini will cut it for your purposes. It sure is a more than enough CPU power. regs
last: PT11.3.1 |
Re: PTMP & Sonar
So what is the most cost effective way to use PTMP on a Mac? Maybe a dual G4 or a G5?
Re: PTMP & Sonar
Base Intel iMac with 2 GB of RAM or a base Macbook with 2GB of RAM.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Re: PTMP & Sonar
Thanks.
Re: PTMP & Sonar
something i'm curious about is, if a base macbook 2.0 will work, why would a mac mini 2.0 not work? BTW, i got PTMP bout 3 yrs ago & i still have the mac disc ( been running pc) what do i have to do when i swap over to a mac. i will need to get all of my current sessions from my pc to the mac, so from there will i have to buy a new ilok or buy PTMP all over again? thanx for any info, always alot of help here.
Re: PTMP & Sonar
HI,
But they will in the near future, I guess. Quote:
OR you can install the "HFS+ enabler" on your Windows side. this allows you read and record HFS+ formatted disks with Windows. Check that PT manual at the bottom of the linked page. http://www.digidesign.com/index.cfm?...4&itemid=23114 Quote:
digidesign account (digi homeapage NOT avidstore) and choose "my Digi Home" there you should find the 7.3 installer for Mac. regs
last: PT11.3.1 |
Re: PTMP & Sonar
ok, thanx for the info, very valuable!! i've never touched a mac so i guess i'm in for a real trip when i convert over. thank you again very much for the info & the link.
can i sell PTMP 7.3/7/4 ilok license and still keep PTMP 8.0 license? | edgarbc1 | General Discussion | 0 | 07-17-2010 01:09 PM |
Sonar omf to PTS | Boesch | Pro Tools TDM Systems (Mac) | 0 | 07-13-2004 07:03 PM |
Sonar 3 | jkung | Pro Tools TDM Systems (Win) | 1 | 12-16-2003 03:42 PM |
Sonar to PT to CD | B. Randall Carter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-21-2002 09:15 PM |
PT LE vs. SONAR ? | CooknKPL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 07-05-2002 02:53 PM |
