Old 12-13-2005, 07:27 PM
mcknight44 mcknight44 is offline
Default Is this possible?
to sync up my 002 and hd24 together to have 40 i/o for recording and play back at the same time
Old 12-13-2005, 10:12 PM
Bastiaan Bastiaan is offline
Default Re: Is this possible?
with 2 computers....probably. But keep in mind that the HD24 is not ptle compatible, so you have to record in a different application. After recording is done you could mix in protools provided you have no more then 32 channels to mix together (limit of ptle)
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 12-15-2005, 05:01 PM
002 can only run 18 I/O at a time anyway.
Old 12-15-2005, 05:17 PM
lemix's Avatar
lemix lemix is offline
mcknight44,
Sure..You'll need to accommodate the combined outputs though..24+8= 32 for monitoring /mixing.
24 is the HD24's full analog output capacity with the DA card installed, and 8 is the max # of analog outs you can get from your 002.
Also ..there is a need for an external hardware sync box, that can either slave to MTC or a printed LTC track from the 002, while able to output ADAT sync via the 9 pin port.
There are a couple of choices out there..Google it.
happy tooling,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
