Transport causing midi ghost notes....
Ok, I searched all the ghost note threads and didn't see this problem out there....so whenever I use the transport controls on my 003 and I have Xpand2 on an instrument track, it will play a series of ghost notes but then they will stay on. I have to use the "all midi notes off" command to get it to stop but it does this every time I hit a trans control on the board. Thoughts? I'm using 8.0.3/4b cs2 on Win7 64 bit. I can't post a Sandra at this time cause my system isn't online. Any thoughts just off the top that I could try?
Ok just found out it's like the lowest note on the keyboard, and it's only 1 ghost note....not sure if that helps. And more weird happenings.....whenever I touch ANY control on the console (fader, save button, transport button....) that makes some kind of change to the session the ghost note plays. Also, if I have 4 or more tracks, the 4th (and only the 4th) fader on my console shoots all the way down while the others on the console (and all on screen) stay at unity (0db). This is nuts....I thought I had escaped most of my problems when I got rid of 8.0.4 drivers but I now have new ones.....great. Last edited by thisistruth; 08-31-2010 at 03:57 PM. Reason: update |
Re: Transport causing midi ghost notes....
Ok, another thing I noticed today was that this only happens when a track is selected, doesn't have to be any track in particular, just a track has to be selected. The only way I found to have NO track selected is to delete one. Other than that I can't find a way to unselect tracks. When no tracks are selected everything works great. But this should work properly regardless........I hope someone can shed some light on this for me.
Alt click on a selected track to deselect it. You can do a Sandra without being connected to the internet. Run Sandra and copy/paste the report to a Notepad document. Move that to your internet computer with a USB pen drive.
Awesome, I'll get a Sandra up tonight. One thing I know off the bat you will tell me from the report is my unsupported VIA firewire chipset. I did not know that only TI was supported when I built my pc. So right off the bat could that be the issue?
I would doubt it. Usually using an unsupported firewire configuration results in having disk read/write and buffer issues. I'm sure by using an approved f/w card, you will have better performance but a Sandra report might uncover something else. Which MIDI controller (if any) are you using?
SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : WORKGROUP Host Name : UpperRoomStudio User : Jon Processor Model : AMD Phenom(tm) II X6 1090T Processor Speed : 3.21GHz Cores per Processor : 6 Unit(s) Threads per Core : 1 Unit(s) Type : Six-Core Integrated Data Cache : 6x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 6x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size L3 On-board Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 6 threads sharing Computer Mainboard : Asus M4A88TD-V EVO/USB3 BIOS : AMI 1308 05/31/2010 Bus(es) : ISA X-Bus PCI PCIe USB FireWire/1394 Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : No Total Memory : 7.75GB DIMM DDR3 Chipset Model : ASUS RS780 Host Bridge Alternate Front Side Bus Speed : 2x 1.8GHz (3.58GHz) Total Memory : 128MB Shared Memory : 368MB Memory Bus Speed : 2x 597MHz (1.2GHz) Chipset Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub Front Side Bus Speed : 2x 1.8GHz (3.58GHz) Total Memory : 8GB DIMM DDR3 Memory Bus Speed : 2x 597MHz (1.2GHz) Memory Module(s) Memory Module : 0A PartNum0 2GB DIMM PC10600U Memory Module : 0A PartNum1 2GB DIMM PC10600U Memory Module : 0A PartNum2 2GB DIMM PC10600U Memory Module : 0A PartNum3 2GB DIMM PC10600U Video System Video Adapter : ATI Radeon HD 5700 Series (SM5.0 850MHz, 1GB DDR5 4x1.2GHz, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 5700 Series (SM5.0 850MHz, 1GB DDR5 4x1.2GHz, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 4250 (SM4.1 700MHz, 384MB 2x667MHz, PCI) Graphics Processor Adapter : ATI Radeon HD 5700 Series (1012MB 4x1.2GHz) Adapter : ATI Radeon HD 4250 (364.5MB 2x667MHz) Storage Devices Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (D:) Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) Optiarc DVD RW AD-7260S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices System Reserved : 100MB (NTFS) Hard Disk (C:) : 466GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Hard Disk (D:) : 466GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Optical Drive (E:) : N/A @ Optiarc DVD RW AD-7260S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ATI (AMD) IXP SB600 SMBUS Controller LPC Hub Controller 2 : ASUS SB700 LPC host controller LPC Legacy Controller 1 : T2 87-21 Audio Device : ASUS IXP SB600 High Definition Audio Controller Audio Codec : Realtek Semiconductor 0892h Audio Device : ASUS RS880 Audio Device [Radeon HD 4200] Audio Codec : ATI (AMD) 791Ah Serial Port(s) : 1 Disk Controller : ASUS SB700 SATA Controller [IDE mode] Disk Controller : ASUS SB700 IDE Disk Controller : ASUS PATA IDE Host Controller USB Controller 1 : ASUS SB700 USB OHCI0 Controller USB Controller 2 : ASUS SB700 USB EHCI Controller USB Controller 3 : ASUS SB700 USB OHCI0 Controller USB Controller 4 : ASUS SB700 USB EHCI Controller USB Controller 5 : ASUS SB700 USB OHCI2 Controller USB Controller 6 : ASUS SB700 USB OHCI0 Controller USB Controller 7 : ASUS SB700 USB EHCI Controller USB Controller 8 : ASUS uPD720200 USB 3.0 Controller FireWire/1394 Controller 1 : ASUS VT6315 Series Firewire Controller Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Media Player : LEXAR JUMPDRIVE (491.48MB) Network Services Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
anyone have any ideas?
What happens if you remove one of the video cards? Love to see a Dverb test on the AMD 6 core
don't know about removing a video card....could that actually have an effect on this problem? what is a Dverb test/score?
http://duc.digidesign.com/showthread.php?t=238426
scroll down about a third to see what the Dverb test as all about. I can't reproduce your issue on my system. Win7/64 bit, LE8.0.4, 003, session with several tracks(all types) stereo instrument track with Xpand2 inserted, any track selected. Maybe you need to force a firmware update on your 003? Wish I could remember how to do it
003 causing midi ghost notes | thisistruth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-11-2010 09:22 PM |
002 ghost MIDI notes | Thuneau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-16-2010 02:30 PM |
Midi ghost notes | lbar11 | MIDI | 3 | 10-31-2009 06:04 AM |
MIDI ghost/duplicate notes problem...HELP! | vocalvoodoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-02-2005 08:12 AM |
Soundcraft Ghost with Pro Tools - transport/MIDI control? | bwherry | General Discussion | 0 | 02-05-2003 01:43 PM |
