Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #21
Old 01-01-2019, 10:25 AM
BScout BScout is offline
Default Re: MTRX hookup question, Dante vs Digilink
Originally Posted by SomeOtherGuy View Post
If a standard converter without conversion is used, does it mean that iTunes or 44.1K system audio would play back at a different pitch when feeding a 48K PT session?
The iTunes engine will sample rate convert what it's playing to whatever the output device sample rate is set at (you just need to set system sounds to 48k.)
However clocking in-built digital audio becomes an issue and so system sounds becomes the master (though the MTRX has a clever "adapt to" function so it can still run on its internal clock but reference an input for what clock it should be at.)
The bigger problem is applications like RX7 which will go by the sample rate of the file it is playing and will do the different pitch thing for a few seconds before it switches to the correct sample rate of the digital output (so it starts to actively sample rate convert.) And this will happen every single time the transport goes into play (it's fairly annoying) and makes shuttling around near impossible while cleaning up a file.
  #22
Old 01-01-2019, 10:39 AM
I should also add that Pro Tools does not like if the MTRX sample rate clock changes while a Pro Tools session is open. If you do it, Pro Tools will complain that the audio hardware has changed (it reads the sample rate changing as the whole physical hardware interface changing) and will ask to shutdown which you have to do and then reopen Pro Tools. I have been stung by this more than once when I allowed "adapt to" to be set to something other than one of the digilink/Pro Tools inputs. Now I leave it with Pro Tools always in charge of the MTRX clock.
(You can, though, open different sample rate sessions as a session isn't open when the change happens)
If you work at one sample rate almost all the time, a lot of these idiosyncrasies will never show up.
  #23
Old 01-01-2019, 01:24 PM
SomeOtherGuy SomeOtherGuy is offline
Thanks, I didn't know how the iTunes engine works. Most of the time all I'll need to do is play iTunes and Quicktime movies, and Safari audio. There also may be times when I'll want to use something like Ircam Lab Timestretch. I only work at 48K, so I hope I can find a way where this is all manageable. With Apogee hardware, it's been a non-issue.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
  #24
Old 01-01-2019, 01:52 PM
lucienpalmer lucienpalmer is offline
I can’t attest for the AES input, but using DVS and Dante, I have the Mac set to be a slave to whatever the master sample rate is (which is always 48). The mac slaves to 48, and iTunes, RX, safari, all play back at proper speed. Even if iTunes is playing back 44k files.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
  #25
Old 01-01-2019, 10:10 PM
Thanks, how do you set the Mac as the slave (in DVS?).
  #26
Old 01-02-2019, 03:44 PM
It’s not in DVS, but once DVS is running, you can set up master and slave options in the Dante Controller software. The controller software doesn’t have to be running all the time. You use it to change settings and routing, then each Dante device remembers their settings after you close the software.
  #27
Old 01-03-2019, 11:29 AM
Great, thanks.
MTRX Dante latency stuck at 1ms LukeHoward Pro Tools | MTRX & MTRX Studio 1 02-19-2018 11:13 PM
MTRX Sync Dante and Video laki Pro Tools | MTRX & MTRX Studio 10 12-05-2017 02:26 AM
HD Native with 2 blue interfaces hookup question Justin1524 Pro Tools HDX & HD Native Systems (Mac) 5 09-03-2013 09:49 AM
Digi 002 Hookup Question jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-29-2004 09:04 AM
Dumb Hardware Verb Hookup Question COCO Tips & Tricks 2 02-08-2001 07:19 AM
