PT11 isn't seeing my 002
I've recently installed PT11 and can't "see" the 003 when looking for it in the "Set up:Hardware" pulldown. I'm also not getting the ElevenRack interface to show up either.
I'm running on a MacBook Pro: - 2.4 GHz Core 2 Duo - 4GB DDR2 SDRAM - OS X 10.8.4 Any and all help would be greatly appreciated...thanks! |
Re: PT11 isn't seeing my 002
Did you install the drivers for the interface? If not you need to.
If need be you can select the main interface by holding down the "N" key while Pro Tools is launching. It should stop at the hardware page and let you select a interface. If you don't see your interface its likely the drivers are not installed correctly. The Eleven Rack interface is not currently working in PT11, you will need to tweak the unit from the front panel or edit it in PT 10.3.7. A future update should restore the functionality. Although there has been no timeframe given.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Hi' popajoe from world wide pc.
i have had this problem whit my builds. go to your pc's control panel sound card and disable all your interface inputs an outputs an for you any other hardware there. then reboot so the OS can disconnect from your hardware now PT WILL OPEN correctly . this must be done ! I hope this help you we like we used we play Have fun not problem! |
The driver "AVID003" is the new one while "DIGI003" is the old one.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
PT11 Possible Bug | Peter Baird | macOS | 6 | 12-31-2013 02:33 PM |
PT11 to PT11 HD Native upgrade without hardware? | kirkbross | Pro Tools 11 | 2 | 11-04-2013 03:10 PM |
PT11 Only 870 meg!!? | ArKay99 | Pro Tools 11 | 2 | 08-30-2013 01:50 PM |
PT11 and PT11 HD differences | Fooks | Pro Tools 11 | 4 | 04-10-2013 12:20 PM |
Will HDX not compatible with PT11? or not the best for Pt11? | Rockman413 | Pro Tools TDM Systems (Mac) | 5 | 10-26-2011 10:00 PM |
