Old 06-04-2008, 04:38 PM
Kevin Mowry Kevin Mowry is offline
Default Control 24 \"Scribble Strips\" - two displays not working
On my Control 24 "scribble strips" #21 and #22 are out (no display). Running the "Vegas" test mode I could get them back by a little light tapping on the display window. Then they'd go out again. But now, no tapping brings them back. All other scribble strips work fine.
I just replaced the power supply with a new one sent by Digi 6/3/08. Board is up and running. So it wasn't that.
Before I put it back in the console, I thought I'd ask if anyone else had dealt with the problem themselves and what they did.
Does it sound like bad connection on just those two displays?
Thank you for any info on this!
Old 06-05-2008, 08:14 AM
Echo studios Echo studios is offline
Default Re: Control 24 \"Scribble Strips\" - two displays not working
With the control24, the only way to get all those issues fixed - and i mean once and for all - is to replace ALL connectors with new molex 3-contact crimp terminal and housings.
Forget the cleaning part if your connectors are loose enough just like mine were. Of course a bit of Deoxit and Progold after re-installation of new connectors is not a bad thing to do also.
You can search the DUC / control 25 for the complete instructions by typing MOLEX.
Once i did that last December 07', i did not experienced anything anymore and its been 6 months that the board is running almost 15 hours a day.
Good luck,
PT HDX2 / Ultimate / D-Command ES 24 w/ edit pack
MP Dual 3.66mhz ( 6-Cores) / 32GB / SDD 8TB
OSX Sierra 10.12
Dan Desilets
Mix/Mastering Engineer, Guitarist, Composer
New Website live @ www.sublimesoundstudios.com
Old 06-05-2008, 11:43 AM
Thanks for the reply and the info Dan. One more question.
I took the bottom and back panels off to get a better look. We are talking about all the white "power connectors" right??, not the ribbon cables? I was supprised when putting in the new power supply how loose the connections fit. No wonder they hot glued everything. What a stupid way to say a few pennies.
Did you do the modifications yourself?
Why would just two displays would go out as opposed to a "bank"??
Thanks!!
Old 06-05-2008, 01:16 PM
Stephen Webster Stephen Webster is offline
Exact same problem here on strips 13 & 14.
These parts available from Digi direct?
Thanks for the info.
Now if i could just clean up the TB mic.
S
Old 06-06-2008, 06:19 AM
Right. All the power connectors (all connections on the PSU in and out for instance) and not the ribbon ones. The connector that makes the most sense in fixing your 2 scribble strip would be the TB4 connector which is a 3 pin, not properly sitting on the PSU because of all the loose connectors which come factory installed.
Once you wil installl the new 3 contact grip Molex - you'll see what i mean - try to disconnect them:)
They will be 100% secure - free of vibrations.
OSX Sierra 10.12
Dan Desilets
Old 06-11-2008, 12:03 PM
Hey guys,
Just a follow up on my problem. I talked to Digi this morning and we surmised that I probably just had defective "displays" in channel bar control board #3. Since the scribble strip displays are on (3) channel bar control boards with banks of "8" displays, it would makes sense that a whole bank would go out if it were a power supply connection problem. My Control 24 is out of warranty so if I install the replacement board, it's about $240 (with exchange)and $950 for Digi to do it.
The Digi rep sent me a PDF with a step by step on how to do the install. Looking at the whats involved, I think I'll let Digi do the repair.
I just wouldn't have the time (or patience )
Old 07-26-2008, 12:19 AM
Artysan Artysan is offline
Default
Originally Posted by Kevin Mowry View Post
Hey guys,
Kevin,
My channels were 9&10. I also had an overall dimming of scribble displays which ultimately became unbearable. When I found the dimming problem, my two intermittently but usually bad channels became normal.
I'm sure shipping is a big part of the $950 repair, but nevertheless, this is the tech support equivalent of asking $5,000 to repair the headlights on your car by sending it to the factory. You should be furious.
The C24 is a very field-repairable device. Or at least it would be if Digi chose to support it by offering technical advice, schematics and parts to owners, just like the rest of the world of professional electronics.
Though I have not investigated the actual cause of a single pair going intermittent, my technical experience tells me that they are somewhat sensitive to supply voltage. My overall scribble dimming seemed directly related to a worsening of the intermittent pair in my controller. When I finally opened it up and located the guilty molex at the PSU, my intermittent pair bounced immediately back to normal behavior and has stayed that way.
Here's two solutions:
Pull the molexes one at a time, clean the oxidation of the exposed pin half of the connector and reseat the receptacle side (the nylon block). This step will tell you if your channel pair is ok like mine was.
Photo for documentation; then pull all molexes to free the PSU. Change the PCB pins to the gold version Molex sells for their serious customers, then replace the receptacle pins as well with the gold version. I have done this on recorders, consoles, etc; and enjoyed a long peaceful coexistence with previously annoying gear.
The gold solution is a bit of work, and you can be selective as opposed to cleaning the whole ship, but if you otherwise love the controller and have the resources (time) the cost is minimal - way less than $240 to do the entire console.
A third and very valid choice is to simply cut off the receptacle end of the offending connectors and solder the relevant wires directly to the PCB Molex pin. Do a very clean job or have someone who can do it for you. It ain't rocket science, but quality is everything with soldering. I have done an entire MCI JH416 console like this and was very happy I did. It was cheap, easy, and rock-solid reliable, with virtually zero downside.
Peter
Scribble strips issue D-Control Fader Pack kptkarl ICON & C|24 0 01-13-2014 10:31 AM
Control 24 Dark scribble displays Firechild Pro Tools TDM Systems (Mac) 4 11-03-2011 09:45 AM
Control 24 scribble strips not working bassinspace ICON & C|24 1 06-05-2011 06:42 AM
002 control surface blank scribble strips Ryan Butler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-15-2008 12:34 PM
Streaky LCD / Scribble Strips - Quality Control? pmh3r ProControl, Control|24, Command|8 3 01-18-2005 06:59 AM
