8.0.3 - More samples in Delay Compensation engine?
Short reports - 2047 samples per channel
Long reports - 8191 samples per channel ? Weren't they half that value before? Did that come in this version or did I miss something on a previous version? This is great at any rate as I felt the previous settings were very limiting. Can someone confirm this?
-cburgett Mixing: ProTools HD 10|Native ~ Avid 96 IO ~ Windows 7 (64-bit) ~ Intel Core2 Quad Q9400 ~ 4 GB RAM ~ UAD-2 QUAD ~ Focusrite Liquid Mix ~ Mackie Control ~ 2 x Mackie Control Extenders Tracking: ProTools HD 10|HD1 ~ Lynx Aurora 16 ~ Windows 7 (64-bit) ~ Intel Core2 Quad Q6600 ~ 4 GB RAM ~ UAD-1e Editing: ProTools HD 10 ~ MacBook ~ Mac OS X Snow Leopard ~ 4 GB RAM ProTools HD 10 ~ HP Laptop ~ Windows 7 (64-bit) ~ 2 GB RAM |
Re: 8.0.3 - More samples in Delay Compensation engine?
I still have the old values. Which sample rate and playback settings are you using?
Same values here
I've changed them around a bit to see if it makes any difference, but currently everything is set as follows:
H/W Buffer Size: 256 samples Host Processors: 4 Processors CPU Usage Limit: 95% Number of Voices: 48 Voices (2 DSPs) Sample Rate: 96kHz Delay Compensation Engine: Short DAE Playback Buffer: Level 2 Cache Size: Normal Plug-In Streaming Buffer: Level 2 Possibly it's because I'm running at 96k? I'll try 44.1 and see if that changes anything.
When I change back to 44.1 I jump down to the old settings ..... DAMN!
Delay compensation engine crash | urfavoriteblbsie | Pro Tools 9 | 4 | 02-25-2012 06:30 PM |
Delay compensation engine | mafiacondon | Pro Tools TDM Systems (Mac) | 2 | 10-11-2010 04:45 AM |
Delay Compensation Engine Fails to Warn | Nathan W. | Pro Tools TDM Systems (Mac) | 2 | 09-17-2010 04:13 PM |
Delay compensation engine!!!! | M2E | Pro Tools TDM Systems (Mac) | 3 | 01-13-2010 09:33 AM |
Max Delay Compensation = 4095 Samples ?????? | Lizardpoint | Pro Tools TDM Systems (Win) | 3 | 12-03-2006 08:10 AM |
