Re: This pop up prevents me from starting Pro Tools
I get this pop up:
CPU usage is holding off USB audio. Remove some plug-ins, delete some tracks, or increase the "H/W Buffer Size" in the Playback Engine dialogue. (-9136) I went to the Playback Engine and increased the size form 512 to 1024 Samples. The same pop up happened after I increased the size. Here are the other settings: The other settings are: 2 processors and 85% CPU Usage Limit DAE Playback Buffer Size: Level 2 Cache size normal. As of now I cannot get a session to record. Any help is greatly appreciated. Last edited by DigiTechSupt; 05-04-2017 at 06:13 PM. Reason: New topic moved to new thread. |
Re: CPU usage is holding off USB audio (-9136)
You give zero system info; without that we're just shooting in the dark.
All we know is you're on a Mac; guessing from the comment about selecting # of cpus and the percentage you're on PT10 or lower. Other than that - zero/zip/zilch/nada. Lots of good people here but we're not mind readers or psychics. |
Any help is really appreciated as I cannot record anything due to the pop up.
This thread was started without my knowledge from a former thread which included my specifications. Here they are below: My specs: Pro Tools LE 8 version 8.0 Mac OSX 10.5.8 Leopard 2.53 GHZ Intel Core 2 Duo Memory: 4GB 1067 Mhz DDR3 computer: Mac Book Pro |
What will help is to put your system specs in your profile with a note either in a post or your sig file to look in your profile for the system specs. A lot of posters do that here - saves time having to repeat or remember to put them in when asking a question. |
Error (-9136) "CPU usage is holding off usb audio" | Hyperacoustic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-10-2009 06:24 PM |
CPU usage is holding off USB audio -9136 protools 6.9 | pughking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-06-2008 10:08 AM |
CPU holding off USB audio ( -9136 ) PLEASE HELP! | ElBingo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-29-2003 09:07 AM |
CPU usage is holding off USB..bla..bla..-9136 | ElBingo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-11-2003 08:00 AM |
CPU usage is holding off USB audio -9136 when running Pro Tools LE 5.2 on Mbox. | keefus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-17-2002 09:09 PM |
