Re: OT: You can't customize PT's "look," can you?
i like standardization, but the present 'look' is boring and pedestrian. it needs an update , with 4 or 5 switchable selections, with original standard being one of them...
www.kfaudio.ca |
Mac Pro 6,1 ("Garbage can"), late 2013, 3 GHz 8-Core Intel Xeon E5; 64GB RAM; MH ULN-2 (Ethernet MHLink connection) PT Ultimate 20.12.0; REAPER64; PreSonus Studio One 5 Pro, Central Station Plus, and FaderPort McDSP All Access; Slate Digital All Access; Waves Diamond 12.0; NI Komplete; EW GhostWriter Finale 26.3.1 |
+1 to this! It's bad enough opening someone else's session and having to deal with their color scheme and window layout.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Mix window in reaper I could work with, but no way with the edit window. Even the mix window doesn't lend itself to the current wide screen monitors most of us are using! Which is where PT mix window is more economical and more suited to wide screens. But a few nice touches on that reaper mix window. Haven't seen an edit window that comes anywhere close to PT in my opinion. Chris
PT's Edit window is by far better than REAPER's, and Logic's as well. Selecting things is so much easier, and since I have a PT keyboard, it's easier yet for me to quickly switch between tools and all that. One of the hardest things to remember these days is what keyboard shortcuts do what in what program. I can't tell you how many times I've tried to use Finale's zoom or drag key combinations in PT or InDesign or whatever. REAPER adds another layer of confusion: In every single application I use, the scroll wheel on my mouse allows me to scroll up and down the window. In REAPER, however, using the scroll wheel zooms in or out in the edit window! (Though I'll bet you that's customizable… ) Cheers, GT
I personally can't stand it, I wish for at least the ability to change the colors of the GUI, the edit window background is too bright for me, and same with the bottom half of the mix window. Staring at Pro Tools bright GUI 24/7 is rough! And I can't dim my screens too much without messing up visibility of plugin interfaces.
HD Native - Apogee Symphony I/O Mac Pro 6 core 3.33 Westmere 16 GB of RAM PTHD 10.2 OSX 10.7.5 |
Completely customizable. Change shortcuts in the action list to mirror Pro Tools so you have to remember fewer shortcuts. Also under "mouse modifiers" in preferences, you should be able to change scrolling behavior.
Good ideas. I'll look into this.
PT's 10 Crashes when performing "Save Copy In" function | soundguy69 | macOS | 2 | 07-07-2015 10:01 PM |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 12:13 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
