Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Win)
Old 05-30-2019, 08:05 AM
timcrow420 timcrow420 is offline
Default Changing DAW. Suggestions?
I Currently have the mbox 3 interface with pro tools express. Im getting a new conputer and i no longer have the pro tools express installation disc.
I was just wondering what you guys would recommend for a digital audio workstation preferably one that works with the Mbox 3 interface
Old 05-30-2019, 09:50 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Changing DAW. Suggestions?
The Mbox, to work with other programs on a PC, requires an ASIO driver. If you have/can find that, then any DAW that uses the ASIO protocol can use the Mbox. If the ASIO driver is part of the PT Express install, then you're obviously going to need the installer.
Per your other thread, you need to solve the BSOD you're experiencing. That may allow you to continue working with your current computer.
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 05-30-2019, 01:39 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Mbox asio drivers are available online.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 05-31-2019, 06:36 AM
junkgear's Avatar
junkgear junkgear is online now
Give Pro Tools First a shot and see if you still want to stick with PT.
There are plenty of others out there and everyone has their own favorite, so I suggest downloading some demos and seeing what fits your needs.
Will K
System Details
Laptop user - changing HW engine - suggestions? BCnSTL Pro Tools 11 0 06-26-2014 11:28 AM
Changing note values while changing meter - I'm stumped jrmintz Pro Tools TDM Systems (Mac) 4 10-30-2011 03:55 AM
changing tempo without changing pitch Sharabelle Pro Tools TDM Systems (Mac) 3 02-10-2007 05:19 PM
Changing tempo w/out changing midi performance??? toddm7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2005 10:35 AM
changing tempo without changing midi wizdoom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-20-2004 05:40 AM
