How to cut record mistakes from any point in pro tools
Hi Friends,
I am dealing with home studio and recording my classical guitar works using beginner level m audio fast track card and pro tools m-powered essential 8. I have one problem in pro tools. I am making mistakes during playing and I am expecting to skip those parts. But the problem is, pro tools is only allowing me to cut the sound as a block in the track. I need to work on very small gaps like miliseconds. Because when I cut the block then my other well played record part is also deleted. What should I do for that ? I tried to attach the screenshot so you can understand me better. As you see on the screeshot picture, Pro tools allows me to cut-copy or paste for each block like for the between 33-34 / or 33-36. But I need to cut much more small parts like the record signed by red circle. |
Re: How to cut record mistakes from any point in pro tools
Welcome to the community.
Pro Tools (Vanilla/HD) audio recording and editing works very well, and I can't imagine Essential differs that much. You can edit down to a single sample. I'd suggest that you record multiple takes (focus on the problem areas), then compile those takes after the fact.
even though I record many times, there will be no difference. Because as I told you and added in the picture, I want to cut very tiny parts between each number (33-34-35...)
Check your grid mode - you may need to change it.
MusicMan.. thanks a lot that was my answer.
New PT rig : want to avoid fatal mistakes | Hazebloom | Pro Tools TDM Systems (Win) | 0 | 03-28-2011 01:34 AM |
CoreAudioManager 7.3 mistakes :-( | KHFohlert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-22-2006 08:47 AM |
Playback/record Start Point | sbchris | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-28-2006 02:13 PM |
And your point is? Record Indiv. or a MIX. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-05-2003 04:37 PM |
DigiBase Guide is full of mistakes. | kmshroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-04-2003 01:40 AM |
